Shift Link Emergency
Old Nov 10, 2008 | 07:03 AM
roadking1893's Avatar
roadking1893
Default Shift Link Emergency
the link below is where you can get the Rod Ends and the rod to replace your shift link if you experienced the pre-mature failure of the stock one. I ordered two rod end, a RH and LH a 11" rod. to Install it I visited the dealership and go the bolts and washer to install. Of course the foot lever end requires a nut and bolt and the trans end screw into the lever. I got the bolts longer to have the machined part of the bolt through the bearing part then cut to desire size. no photos just yet.
http://www.boomerangracing.com/
Old Nov 10, 2008 | 07:30 AM
harley-jones's Avatar
harley-jones
The stock rod takes only RH thread ,female rod ends (heim joints).
Old Nov 10, 2008 | 07:59 AM
harley-jones
Here is a pic of the stock rod and two RH rod ends.
Old Nov 10, 2008 | 11:30 AM
DrPlastic's Avatar
DrPlastic
One this that has made me wonder as to why Harley puts R/H threads on both ends. A proper linkage like this is suppose to have a left and right hand thread so you can just rotate the rod to change the length.
Old Nov 10, 2008 | 12:58 PM
Northside's Avatar
Northside
Harley sells heim joint ends #33871-85B. Mine cost $10.00 apiece. They're both RH thread, just measure the rods original length and screw them on to the old rod, after removing the ball joints, to achieve the same length. You'll also need a 5/16-20 x 1' bolt in the rear joint and use a little blue loctite, Too cheap not to do considering how cheesy the stock ball joints are.
Old Nov 10, 2008 | 01:33 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
I bought the parts, still need to install
Old Nov 10, 2008 | 03:33 PM
roadking1893
For the RH/LH rod end with jam nut and the 11'" rod was 15.00 the hardware, two chrome bolts, 2 washer and 1 lock washer was 5.00 at the HD dealer. My old shift linkage was still good now it is my spare in the event this one does not hold up.
Old Nov 10, 2008 | 03:50 PM
Geoff's Avatar
Geoff
The stock linkage should be replaced as a preventive maintenance measure. The design is weak.
Old Nov 10, 2008 | 03:59 PM
FastHoss's Avatar
FastHoss
I did the heim joint mod to mine,it seems to work good,but the rod stays kind of stiff,does not rotate easily back and forth,my friends does ,is this a issue?
Old Nov 10, 2008 | 04:10 PM
badblue's Avatar
badblue
what's the emergency? I have 23,563 miles and never an issue with the shift linkage.
