If you look at Soos picture above you'll notice that his "U" bar is incorrectly attached to the tour pack. It should be in the cradle. (See image below.)
The "U" bar attaches to the TP at the back of the "U" and has four (4) other screws that go through the TP, "U" bar, round to flat spacers and the chrome detachable rack. The stock detachable has holes to move 1 or 2 inches. The Kuryakyn kit allows another 2 inches. AT least that is how it works for 05-07 Touring bikes.
If you look closely at the bottom of an '06 tourpak (which is what I have ) you would see that there are 2 channels which are spaced 3/4" apart C/L to C/L to allow for positioning of the tourpak 3/4" forward or backward. You can't see the 2nd channel in my pic because my "U" bar is correctly located in it and if you look closely at the 2nd pic you can just make out the raised inner lip that defines the channel
It's amazing what the sales people and service writers don't know....and don't want to learn, just tell you a bunch of lies to try to sell you a bike. My one dealer told me all HD seats were real leather.
From: We live in Beautiful,Sunny,Windy,Snowy,Cloudy,Foggy,Rainy,Hot,Dry,Misty,Blue Sky Colorado Springs!!
Sir,
have an 03 heritage and just installed 2up leather tpak, wife says she lost room,saw your post from a few years ago on a tour pak project u did, can u tell me if the kuryakyn quick adjust reloactor can be made to work ?
+1the salesman who sold me my 09 Ultra three years ago knew about it
Originally Posted by frog13
Doesn't matter if it's detach or not, there are additional holes in the mounting system to unbolt and move it. I believe it comes in the most forward position. It is not something that can be done on the fly, it requires unbolting and reattaching. If that doesn't give you what you want, I highly recommend the George Anderson Tour Pak relocation kit, search on the forum, you will find it.
The 08s have 2 positions but when I looked at a friends new 09 Ultra I thought it had 3. Look at the bottom of the TP and it should be obvious. As mentioned before it is not a on the fly change it has to be unbolted and moved. As to why
A plus size passenger would probably require a little more room back there especially if when using a rider backrest.
Common sense answer. Get down on your knees and look at the bottom. Right after looking at the date on this thread.
I use the Tim Sights relocator. Goes solo or 2 up. Pull the lever and just move.
I like that one, how is it on the solo ride with the tourpack as your backrest? Got a link where I can get one? Do you have to install a solo seat, or does it slide over the existing 2-up seat?
