Fuel Injectors
Old Apr 5, 2006 | 08:45 PM
Timex's Avatar
Timex
Default Fuel Injectors
Had new Injectors (25 degree) installed this morning. A noticable increase in "zip" with smoother and lower RPM's. Not sure about a dyno. Any thoughts out there ???
Old Apr 5, 2006 | 11:50 PM
Ready2Ride's Avatar
Ready2Ride
Default RE: Fuel Injectors
How can I tell what style injectors I have?
Old Apr 6, 2006 | 10:29 AM
CHEYENNE's Avatar
CHEYENNE
The Part number is listed on the side of the injectors. If you do a search for Injector Number I'm sure you will find the thread with the paart numbers posted.
I got mine ran on a dyno so that I would have a baseline before adding the exhaust. It's not needed though. Unless you have had your bike dyno tuned before the injectors then yes I would have it redone again.
Old Apr 6, 2006 | 11:12 AM
Timex's Avatar
Timex
Will the map prior to my new injectors still be dialed in ok with the new injectors? Seems to run better already.
Old Apr 6, 2006 | 11:24 AM
Isshinryu's Avatar
Isshinryu
I had the 25 degree injectors installed and I did not notice any increase in performance. It did increase my gas mileage by 5 miles per gallon! I really appreciate that. I now get about 46 mpg.
[IMG]local://upfiles/6262/6AC683A9D9E644DC9C2E1C72609E5CF2.jpg[/IMG]
Old Apr 6, 2006 | 11:25 AM
skos's Avatar
skos
Is injectors on both carbed and EFI?
Old Apr 6, 2006 | 04:03 PM
Matt115's Avatar
Matt115
ORIGINAL: skos
Injectors are only for EFI models. Carbed models have....carbs[&:]
Old Apr 6, 2006 | 10:02 PM
jkoch09ultra's Avatar
jkoch09ultra
I picked my bike up this evening. Had the 25 degree injectors installed. Runs much better. I will have to run a tank thru before I know about milage. Smoother at low end. Will have to see if it is better with cold start. Used to cough and just about through me off. Runs so good I may not need my PCIII anymore. We will see.
Now runs like a Harley should. To bad I had to bitch and moan about it for 6 months and listen to the dealer saying that it is all normal to run like ****.
Old Apr 6, 2006 | 10:53 PM
Ripp's Avatar
Ripp
I to picked up my bike today with the 25 degree injectors. It seems to run stronger, about the same as when I had the PC3, se filter, and Kerker slip-ons. The dealer had me put the bike back to stock before they would install the injectors. I can’t complain I dropped the bike off Saturday and it was ready Tuesday with the injectors and new down load. I will check the gas mileage this way then swap back to the PC3 and check.
monster715
Engine Mechanical Topics
15
May 7, 2016 09:48 AM
jmr1971
Sep 29, 2014 01:37 PM
wydopn231
Apr 19, 2008 10:54 PM
petemac
May 15, 2007 03:20 PM
richp5
Apr 5, 2006 11:00 PM
