Harley Oil Cooler Kit
Old Nov 11, 2008 | 05:52 PM
ramnj's Avatar
ramnj
Can you post a pic?
Old Nov 11, 2008 | 06:17 PM
xcelr8's Avatar
xcelr8
Originally Posted by Dr. Combustion
Oil coolers are not worthless in traffic; they are just not as effective since only radiation is available for cooling. Add fans with a thermostat for better performance. Harley knows what they are doing by setting the their thermostat at 175 degrees. Moisture is not the primary concern. Think about it. This is a closed system. Even if the temp of the oil goes to 300 degrees and any moisture changes to a vapor, it will simply condense back to a liquid once the oil temp drops. There is no moisture removal system within the oiling system. If you see moisture in the oil (chocolate milkshake appearance), then there are significant problems.
Agree that the fans are the answer to lower temps in traffic, however the system is not entirely closed. Overfilling the crankcase will result in oil being blown out through the air cleaner, and I would have to think (not positive on this) that the burned off condensates would be released the same way. No question that the boys at the MOCO know what they are doing, but I'm simply saying that if the oil temp is within specs, why would anyone actually need the cooler?
Old Nov 11, 2008 | 06:56 PM
RODEO's Avatar
RODEO
Don't forget that there's another 1/2 quart of motor oil in the system then too, which contributes to oil cooling just because of the extra capacity.
Old Nov 11, 2008 | 07:22 PM
jag1886's Avatar
jag1886
Everyone always says you need to find a 7/16 allen wrench, well you don't I used a
1/4" X 1" bolt with about 5 nuts all locked together and put that in a 7/16 socket and you have a 7/16 allen wrench that fits on your rachet. I worked for me!!
Old Nov 11, 2008 | 08:02 PM
papifun's Avatar
papifun
ere is a question. I have a 2008 SG with the cylinder deactivation when engine temps gets hot. would this be same as the oil cooler ? temp here rarely gets abouve 85 in the summer... any comments ?
Old Nov 11, 2008 | 08:15 PM
r0de_runr's Avatar
r0de_runr
You might be able to get it tight enough with that.
But you will never remove it again without a good 7/16 allen wrench. I needed a 1/2 inch drive wrench with an extender bar to get mine back off.
Greg
Old Nov 11, 2008 | 08:46 PM
LH's Avatar
LH
no, that's a completely seperate system. I have both systems on my bike down here but I don't think you'd need an oil cooler up there.
Old Nov 11, 2008 | 10:33 PM
xcelr8's Avatar
xcelr8
Plenty of opinions on this very subject in other threads. Actually, it's right up there with "What oil should I use?"
I would have to say that if your oil temp is within specs (220-240), a cooler is a waste of money. For those that are consistantly seeing temps of 250+, an oil cooler, along with the Baker 5 quart oil pan, and synthetic oil would be a good idea.
I guess what I'm saying is "If it ain't broke, don't fix it".
Old Nov 12, 2008 | 12:07 AM
sifularson's Avatar
sifularson
Blah, Blah, Blah. If you don't believe in oil coolers . . . good for you.
EDIT: I'm sorry for misspeaking. Consider my hand slapped.
Yes, I have an oil cooler on my bike for good reason.
Old Nov 12, 2008 | 12:21 AM
Hawghauler's Avatar
Hawghauler
Talking
Both my wife's and my bike have oil coolers and we found them well worth the effort. We frequently run in hot places or run at speed for long distance and have found the coolers contribute greatly to heat reduction. They do help in very slow traffic, but I prefer traffic avoidance to combat that trial. I also agree that more oil storage = less heat. Gee, maybe I'll mount one on my Briggs and Stratton
