Harley Oil Cooler Kit
Old Nov 12, 2008 | 07:58 PM
  #31
46knuck's Avatar
46knuck
Originally Posted by SCRider
I just installed a HD Premium Oil Cooler last weekend. I have a 95" motor with 204 cams. My bike would run from 225 to 245 in the winter and 250 to 270 in the summer. Way too hot. And yes, I have always used Synthetic oil. I also ride about 12,000 miles a year. After reading the article in AIM I decided that an Oil Cooler was a good Idea to help extend the life of my motor. After riding 200 miles with the new oil cooler last weekend the hottest my bike got (in 85 degree weather)was 215!!!Much better.
Harley Davidson will have to make the same decision Porsche did back in 1998 and go water cooled very soon to meet the ever increasing EPA emissions standards. So I want to protect and preserve my air cooled Twin Cam.
The installation was simple but they should have mentioned the very odd 7/16 size Hex nut required!
All of the above is what I also hear. My summer days often go above 100 so I plan on one or the other also. One article did mention that odd hex nut.
Old Nov 12, 2008 | 08:04 PM
  #32
sifularson's Avatar
sifularson
Originally Posted by RjCapp
What I like most about having the HD Oil Cooler or any cooler is that you can actually see a drop in oil temp when you start moving again after stop and go. Max temp on 90 degree days are 220 if that and I see a quick 5 degree drop on the oil temp gauge if temps do rise.
Before installing a cooler once the oil temps rose it was impossible to reduce temps even after increasing speed/air flow. The only way to reduce temps was to shut down and let it cool.
I strongly recommend oil coolers.
+1 . . . What you said is right on. I noticed the same thing. I can get stuck in traffic and the temp starts to raise and then it cools right down in just a couple minutes of riding.
The reason I got a cooler was because I got stuck in traffic after pushing the bike hard at 80 in the California desert. My oil temp rose from 250 to over 300 in 10 minutes. That's when the rear cylinder base O-ring started leaking. ouch! Had to have the motor torn down and both cylinder O-rings changed at around 4000 miles.
Not a single issue since installing the cooler.
BTW, I've sent two emails to Donny Peterson on this subject. Wanna know what he said?
"Heat will be the downfall of the Twin Cam."
Old Nov 13, 2008 | 06:06 AM
  #33
captjon37's Avatar
captjon37
Originally Posted by xcelr8
The last time I checked, this was a "forum", where members are entitled to express their views. On the other hand, the guidlines are quite clear, regarding the posting of abrasive comments regarding other members. You are entitled to your opinions and I am entitled to mine.
And lastly, realizing that the MOCO has an extremely sophisticated engine research and development program, I would have to favor their specs and recommendations over any individuals "backyard" engineering.
The problem is you have stated your opinion against oil coolers several times as if trying to convince yourself you don't need one. Your opinion is as old as you. Don't get one. I am sure no one will miss that putrid colored bike on the highway after it pops from overheating. You should really read what your helper types before he post it. You are contradicting yourself. Glasses wont hurt either.
Old Nov 13, 2008 | 01:46 PM
  #34
iclick's Avatar
iclick
I agree with AI magazine that all TC motors should have an oil cooler. Like the OP I also nixed the chrome cover for two reasons. First, that big chrome thing calls attention to a part of the engine that doesn't need attention. Second, I felt that it might hinder cooling by convection when the bike was stopped.
I took another step partially to help with stationary cooling and partially to satisfy my longing to jury-rig and experiment. I have two fans installed inside the cooler, and although they don't stop oil-temp from climbing while stationary they do slow it down, which IMO makes them worthwhile. I wrote up the fabrication here.
The ACC switch on the left (bottom pic) is the switch that controls the fans. So far so good on these Panasonic Panflos, which survived their first summer of heat and water without dying. I do not operate the fans unless conditions are dry, as they are not waterproof.
I would advise anyone installing a cooler to also include a thermostat. These air-cooled engines take long enough to warm-up, especially in winter, and cooling cold oil doesn't help. If you don't install a t'stat, use a cover to keep the air off the cooler when the air-temps are not hot.
Old Nov 13, 2008 | 03:29 PM
  #35
Dr. Combustion's Avatar
Dr. Combustion
One might also consider using another thermo switch to detect when the oil temp reises to a certain temp, say 200 or 210 degrees. This extra thermo switch could then start the fans automatically. This is my approach.
scootertramp
Oil Archive (no new posts)
May 3, 2013 08:59 AM
whylee
Oct 14, 2008 07:41 PM
tonygret
Apr 14, 2008 10:18 AM
hitchhiker2706
Jan 13, 2008 12:17 PM
msbhvn
Mar 2, 2006 10:46 AM
