View Poll Results: Which Stabilzer
Bagger Brace
37.78%
True Track
5.56%
TRW - Missing Link
37.78%
Ride Str8
8.89%
Terry Components
0%
Glide Pro
3.33%
Sta-Bo
6.67%
Voters: 90. You may not vote on this poll
Which stabilizer is best
Old Nov 13, 2008 | 07:22 AM
  #31
1flhtk4me's Avatar
1flhtk4me
Asking which stabilizer is the best one is like asking which exhaust,oil,tires,seats are the best.The end result is your going to get a million opinions.All these things do the same thing.
Myself ,I went with the affordable one that looks like it will do the same thing as the others.
Old Nov 13, 2008 | 10:52 AM
  #32
6 gun's Avatar
6 gun
+1 opinions are like A-holes everybody has one! What you need to do is buy the one that makes you Happy and don't let me or anyone else rain on your Parade.
Old Nov 13, 2008 | 11:27 AM
  #33
Yachtman's Avatar
Yachtman
RockNRod,
I'm not trying to diss anyone or their product. My point is that there is another new stablizer every month. Even a top shelf company like Progessive is new to the stabilzer game. So even they will need time for their Stabilzer to get out to riders and get real time riders use. So unless someone already has a few thousand miles on their new "(fill in the blank)" stabilzer, they shouldn't chime in to say 'it's fantastic!". And if someone doesn't even have one, they can't have an opinion of the product, period.
Again, I meant no disrespect, or any offense, to anyone. As I stated earlier.
Old Nov 13, 2008 | 12:42 PM
  #34
brooklynflhrc's Avatar
brooklynflhrc
Default Stabilizer
Hi , I don´t know if I need one on 2009 Road-king .
yes or not ? respect to the new frame.
Thank´s.
Old Nov 13, 2008 | 01:48 PM
  #35
Clint55's Avatar
Clint55
Originally Posted by Yachtman
RockNRod,
As said before, I don't own a stabilizer yet. Still doing the research. But I CAN and DO have an opinion, period.
I am very interested in the discussions regarding materials, workmanship, clearances, tolerances and compatibility with other items such as jacks, center stands, etc. Comments about customer service are also important to me.
By the way, I've also never met or experienced Angelina Jolie, but I definitely have an opinion!
I also mean no disrespect or offense to anyone
Old Nov 13, 2008 | 06:06 PM
  #36
Primo's Avatar
Primo
Originally Posted by TRVSDAD
TRUE-TRACK check his website. You'll see why I chose it over the copys.
+1. Besides I don't mind paying more for the original.
I could have bought a metric cruiser. They look almost like a Harley and are a lot cheaper but I wanted the real thing.
Flame On. Nomex Coveralls donned.
Primo
Old Nov 13, 2008 | 07:23 PM
  #37
2106HD's Avatar
2106HD
The more I read the more I get unsure, maybe I don't even need one..............
Looks to me that the bagger brace is REAL nice, compact, and well made ($289), but am also considering the $145 throttle-up model (price is right). One thing I am not sure about on the throttle-up (and similar models) is the way it mounts using so many long pan bolts. Would this method put unengineered strain on the pan and those bolts as the stresses push and pull thru the unit?
It looks like the bagger brace does not use but the back 2 of these bolts. Is this true?
I am unsure if it's worth 2x the money if the throttle-up is good enough to do the job. Others may be "over-kill" (and over-priced) to do the same job?
Old Nov 13, 2008 | 07:24 PM
  #38
btbill's Avatar
btbill
Default stabilizer
Been watching this "debate " for quite a while now.
Last week I felt the dreaded wobble for the first time.... so yes, I'm in the market.
I have a friend who does installs for the glide pro and I believe that soon I will be trying out this product. I like the price and reviews of the Bagger Brace,but I think that it would be nice to have a fix that is out of sight.
Plan on getting a new rear tire ( Metz. ) and the stabilizer in Dec. If anyone is interested I plan on doing an evaluation on both the Metzler and the Glide Pro.
Good to see so many opinions on the forum, hope that I may be able to help someone out by my experience.
btbill of sunny socal ( been getting chilly here in the early mornings )
Old Nov 13, 2008 | 07:42 PM
  #39
Yachtman's Avatar
Yachtman
An image just came to me.
Take a 6' long, 4" metal pipe and lay it on the ground. Then take a 6' long, 2-4" PVC pipe and slide it in to the metal pipe all the way until there is 3-4" sticking out. Now stand on the metal pipe and try to snap the PVC pipe off. It should be hard to do. Now take and slide the PVC pipe out so there there is 4-5 feet sticking out, stand on the metal pipe and try to snap the PVC off. Should be easy to do. Now lay four of these contraptions next to each other, bolt the metal and the PVC together, and try both ways again. I'll bet you can still break the longer section off easier than the short section, even thought they were tied together for extra strenth and rigidity. And even if you're not strong enough to break it off, I'll bet you can crack it up pretty well.
Or.
Imaging trying to break the stuck lugs nuts off your car tires wheel with a 2" rachet, and then try it with a 24-36" 'breaker' bar. The longer bar should 'break' the nuts loose.
And now I have a question. How many people that have put a stabilzer on their bike took the time an expense to check, and replace if needed, the swing arm bushings? Especially on older bikes. Wouldn't these parts be the first to get worn and give problems, such as 'wobble'.
Or has marketing ("I have one too!!") caught up with, and over run, everyone.
Sorry.
Old Nov 13, 2008 | 07:58 PM
  #40
2011 Road Glide Ultra's Avatar
The Bagger Brace uses 6 bolts in the pan, 2 of which are long. After looking at photos of every brace/stabilizer I could find online, I believe the Throttle-up is the only welded steel unit available. As far as I can tell, all the other units that "cage" the oil pan on the tranny use machined aluminum cages. If the Throttle-up unit proves strong enough and doesn't have issues with the powdercoating, it will prove to be the cheapest solution - at least until somebody buys one and starts duplicating it offshore. Harbor Freight has a heck of a wheel chock that goes on sale for about 20% of the US-sourced one.....
