Hope I'm Wrong
Old Nov 13, 2008 | 11:34 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Default Hope I'm Wrong
I bottomed up my outer fairing a few days ago. Now I want to remove my fairing cap to change fork oil.
I read in the SM that the outer fairing has to be removed, radio shifted and a wire strap cut to allow the cap to come off...
Is this correct?????
Old Nov 13, 2008 | 12:04 PM
Baddflhtcu's Avatar
Baddflhtcu
Last winter I tore mine ( 07 Ultra ) down to paint inner fairing. I had outer, inner and fairing cap off and never moved radio. I beleive you can just remove your lower cap. It's worth a try, if not then you'll have to remove more.
Old Nov 13, 2008 | 07:54 PM
Uncle Scrooge's Avatar
Uncle Scrooge
Don't know about an 09, but not necessary on an 06.
Old Nov 13, 2008 | 09:17 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Just found another fairing cap removal page in the SM and it does not say anything about the outer fairing. Remove ignition switch, remove the 2 side screws, lift up cap and unplug connector. I feel better now.....
Old Nov 13, 2008 | 09:36 PM
Bertk's Avatar
Bertk
You are correct. All that has to be removed is the ignition switch **** and the fairing cap. I recently changed the folk oil on my 08 SG and added the HD SE Performance Fork Oil "Heavy". I would suggest reading through this thread before doing the job. You will find some good tips and tools needed.
Old Nov 14, 2008 | 03:19 AM
leon anthony's Avatar
leon anthony
the fork tube plugs are 36mm and in a very tight spot to get to if you have the harly
tool kit with the flat 36mm box end wrench that is the tool to use fits in the tight spot
Old Nov 14, 2008 | 06:36 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Thanks for the advice guys...
BuddyK
Jun 30, 2014 06:46 AM
Toliverpeterson
Sep 3, 2012 05:24 PM
dpcalli
May 5, 2012 07:50 PM
FFeric
Apr 10, 2009 10:33 AM
BlackGlide
Mar 1, 2008 07:39 PM
