Remove industrial velcro from inner fairing?
Old Nov 17, 2008 | 11:43 AM
beary's Avatar
beary
Originally Posted by hammerhead32158
Use " skin so soft" from avon. Just put a little on a rag and rub. It takes off glue and will not hurt the plastic. Go ahead and flame on me. My wife showed me. Just think what it would do for your skin.
Isn't that the same stuff you take on campouts to repell bugs, start fires and use as a creamer in your coffee?
Beary
Old Nov 17, 2008 | 11:54 AM
hammerhead32158's Avatar
hammerhead32158
Default Why yes
Beary
Why yes, yes it is. I see you use it too. LOL
Old Nov 17, 2008 | 12:29 PM
Leftcoaster's Avatar
Leftcoaster
Any automotive paint supply outlet should have adhesive removal wheels that will fit in a drill or die grinder. They make a mess but should work without discoloring the plastic if you don't overheat it. 3M also makes an adhesive remover for stickers, etc. that may be helpful. I've used this and it works well. Try anything you do on an inconspicuous location first just to be sure. Good Luck.
Old Nov 17, 2008 | 03:20 PM
zoood's Avatar
zoood
Former Sponsor
Originally Posted by Rain
The previous owner of my 02 FLHTC stuck industrial velcro strips on the inner fairing to the left and right of the speedo and tach. I'd like to remove one of them and trim the other down some but wonder if I'll mar the finish on the inner faring doing so.
I know I can heat it with a hair dryer to pull it then maybe get away with using Goof Off or Goo Gone to get the adhesive off but am not sure if this will discolor the fairing.
Anyone removed it from theirs and how did it turn out if so.
After you follow the advice on here for removal of the adhesive. If you still have some fading or variations of the finish on the inner fairing surface. Go back to the dealership and for 6 bucks,... purchase that novice #2 plexi glass windshield polish. Red & white plastic squeeze bottle. hand polish that area just as you would your windsheild. It will bring the fairing back to new.
RJ
Old Nov 18, 2008 | 06:42 AM
Rain's Avatar
Rain
Never thought of this. I'm pretty sure my wife has some of this around. I'll give it a try.
Old Nov 18, 2008 | 07:16 AM
1flhtk4me's Avatar
1flhtk4me
Definatly dont use goof off.It has acetone in it and will eat the plastic.
I tried it while removing the edge trim adhesive.Turned the black plastic to a hasey white color.
Old Nov 18, 2008 | 09:26 PM
Rain's Avatar
Rain
RJ
Great idea, thanks. And thanks to everyone else with suggestions. I'll post Skin So Soft reults once I get a chance to try it, hopefully this weekend.
BelchFire
Mar 28, 2024 11:11 PM
bbissell
2014-2024 Touring Models
11
Feb 15, 2022 11:37 AM
IzzoQuazzo
Mar 22, 2017 08:02 AM
Jmbeebe0722
15
May 19, 2014 02:57 PM
bigbean78
Nov 13, 2007 10:01 AM
