I'm learning patience!
Old Nov 16, 2008 | 11:56 AM
Jonny Cannon's Avatar
Jonny Cannon
Default I'm learning patience!
Bought chrome switch housings & chrome switch caps.
Got the throttle side done. It's together but not completely installed - the chrome master cylinder hasn't arrived yet. I'll finish it up when that comes in.
Just sitting here, having a beer, putting band-aids on my hands, psyching myself up to do the clutch side. I find that big fat Polack sausage fingers are not cut out for this work.
The switch caps aren't as hard to do as I was told. There's a bit of a knack to it, but if you try it the way the instructions tell you, they go on pretty easily. This job would be much easier without the auxilliary controls (cruise, CB, etc). Packing all the wiring, etc back into the new switches is the worst part.
I have found that re-installing the throttle cables on any HD are way easier, for some reason, than on any crotch rocket I have worked on.
*sigh*
Well; here goes the other side.
Cannon
Old Nov 16, 2008 | 02:13 PM
Bertk's Avatar
Bertk
Been there, done it, good luck!
What year bike are you doing it on?
Old Nov 16, 2008 | 02:24 PM
oldhippie's Avatar
oldhippie
I've heard a few horror stories about kinked wires inside those assemblies causing all sorts of problems when installed by your local friendly HD deaqlership. Then once the damage was done, keeping the bike for weeks as they try to undo the damage they did.
So, the moral of the story is do it yourself and have a lot of patience.
Old Nov 16, 2008 | 03:06 PM
ENTERPRISE's Avatar
ENTERPRISE
You are right about there being not alot of spacein there.but once you do it the next time it goes alot smoother
Old Nov 16, 2008 | 03:10 PM
Jonny Cannon
It's a 2007 Ultra.
I seem to have hit a snag. I believe I have royally screwed something up. I checked for kinked wires, etc. Nothing. Now. Brake lever & clutch lever are completely unattached from the bike, so both plungers on either side (brake switch & clutch override switch) are not depressed.
I turn the ignition on, and the bike fires up immediately, without my touching the starter switch. Kill switch works. Starter switch appears to be working fine and is installed correctly.
Any idea what I did? I've got to think this one out.
All other switches work - signals, etc. Why the hell does the bike instantly fire up when I turn the ignition on?
Cannon
Old Nov 16, 2008 | 03:43 PM
Jonny Cannon
Cancel that - figured it out. More sausage fingers. Everything works correctly.
Cannon
PGDredd
Apr 3, 2012 08:39 PM
shortride
Nov 26, 2010 08:50 PM
classicruizer
Mar 25, 2010 02:03 PM
krub6t9
Apr 11, 2008 10:07 PM
canuk cruiser
Jan 25, 2006 01:15 PM
