04trike
Old Nov 17, 2008 | 12:43 PM
04trike's Avatar
04trike
Stage III
Lightbulb 04trike
on my 2004 dresser my cd player quits working going down the road. can some one tell me how to fix the problem
Old Nov 17, 2008 | 01:34 PM
Gutman's Avatar
Gutman
Check to verify the handlebar clamps are not contacting, or have contacted the bottom housing of the stereo. Have seen alot of these.
Old Nov 18, 2008 | 06:37 AM
04trike's Avatar
04trike
Stage III
Yes i checked the handle bar clamps they are not touching the bottom of the radio & i can`t see any marks on the bottom of the radio
Old Nov 18, 2008 | 08:12 AM
Harleypingman's Avatar
Harleypingman
Call Radio Sound customer service: 502 267-6768, and ask for John (IIRC)--they were HD's vendors on those headunits.
Old Nov 18, 2008 | 10:33 AM
robzuc97's Avatar
robzuc97
You didn't indicate what was wrong so maybe these will help to localize:
RADIO DIAGNOSTICS
To enter the radio diagnostic mode, press any two (2) station preset buttons simultaneously while turning ignition on. There are five (5) diagnostic modes (D1-D5) plus Automatic Volume Control (AVC) setting. Digits will change from 0 to 1 when function button is operated. If digit does not change, there is either a short or open on that circuit (see Service Manual or ED for codes). To cycle through the various diagnostics, use the LO/DX button.
D1: Switch Function Mode will display a five (5) digit binary code at the top of the LCD.
Digit 1=Mode set, up & down
Digit 2=FPTT, RPTT, Volume up & down
Digit 3=Audio in, Squelch-, Eject
Digit 4=Audio-, Squelch+
Digit5=Audio+
D2: LCD displays an 8-digit code
Digit 1=PTT microphone Digit 2=Vehicle speed Digit 3=VOX break Digit 4=CB SQ break Digit 5=IC on/off Digit 6=CB on/off Digit 7=SPKR SW B Digit 8=SPKR SW A
D3: LCD function=Illuminates all display items in LCD.
D4: Model year=Select model year as prompted.
D5: Software=Displays software information
AVC: Automatic Volume Control=Adjusts volume to engine speed. 0 to 4 range with 2 the factory setting and 4 being the most aggressive setting.
bk5
Apr 11, 2019 07:01 PM
DDuess
Jun 4, 2013 02:22 PM
leadman
Sep 27, 2010 09:11 AM
matthewthamm
May 7, 2010 03:01 PM
Jinxie
EVO
Aug 27, 2007 05:42 PM
