Rear Brake Pads '09
Old Nov 22, 2008 | 03:26 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Default Rear Brake Pads '09
Just for your information, the rear brake caliper on my '09 SG could not be removed from the rotor with the wheel attached and the bike up on a lift.
It is not necessary to remove it to replace brake pads though. If you read the SM, it does state to remove the caliper from the rotor.
I just replaced my factory pad with Lyndall Z-Pads. Old pads (800 miles), dropped out, new pads were inserted without an issue. It does make it easier if you remove the caliper mounting bolts so the caliper can be moved around some...I didn't even have to compress the pistons, there was plenty of space to slide the new pads into place.
Took about 10 minutes....Now onto the front ones.....
Old Nov 22, 2008 | 03:57 PM
lp's Avatar
lp
It was tight, but I was able to remove my caliper. The Z pads are awesome too...
lp
Old Nov 22, 2008 | 04:01 PM
HDV-GLIDE's Avatar
HDV-GLIDE
lp
Without marring up your wheels???
I've learned not to force things off of motorcycles or cars. You end up with scratches and high blood pressure!!!
Old Nov 22, 2008 | 04:14 PM
tommyj's Avatar
tommyj
Default Brake pads 09 Ultra
Will these pads fit an 09 Ultra? How much and where did you get them..? I have 5500 miles on mine and will need some soon if you needed them at 800! Mine looked good at the 5000 mile maintenance check. Thanks.
Old Nov 22, 2008 | 04:23 PM
lp's Avatar
lp
Yup. Never even touched the rim. I've learned to just take your time and things come off like they are supposed to. Easy...
lp
Old Nov 22, 2008 | 04:55 PM
HDV-GLIDE's Avatar
HDV-GLIDE
My stock pads were like brand new....I replaced them with the Lyndall pads for no more brake dust, no noise and longer lasting.....
murrdogg88
Jun 24, 2017 11:50 AM
warthawg
Sep 25, 2016 09:58 AM
mteed23
Mar 16, 2012 05:49 PM
jlasoftail
Apr 21, 2011 11:11 PM
OU812
Jun 27, 2010 05:42 AM
