Need help installing additional speakers
Old Dec 1, 2008 | 09:00 AM
Sincecrazy's Avatar
Sincecrazy
Default Need help installing additional speakers
Im wanting to add two speakers to my fairing lowers, and power them with the HK fac head unit. Bike is an 08 Roadglide. Do I need a harness to add additional speakers and should I add an amp to power these?
Old Dec 1, 2008 | 11:47 AM
Harleypingman's Avatar
Harleypingman
Shoot PEZ a PM and ask him. He's the owner of Hog Tunes and offers a kit for what you want to do.
With the HK radio, IIRC, the rear speaker signal is accessed using the Ultra connector at the rear of the headunit. That Ultra connector is usually accomplished using the Ultra overlay harness that would carry not only speaker signals, but also PTT, volume and other functions for the rear passenger. You could fab your own getting the part numbers from the HD store and it would be less expensive than buying the overlay harness. You would need the dealer to flash your ECM to "turn on" the rear speakers/tell the headunit to power them--at least that's my understanding regarding the ECM. I have fabbed ultra connectors for other applications and it's not difficult.
You could also tap the outputs for the front speakers, but that involves placing additional load on the circuits which I'm not sure would work well for you.
No, you wouldn't need an amp since you are going from two to four speakers like an Ultra and they don't come with seperate amps.
Good luck with your project.
Old Dec 1, 2008 | 11:56 AM
HDUltraRider's Avatar
HDUltraRider
+1 for hog tunes.... and Pez
Old Dec 1, 2008 | 06:10 PM
blueflht's Avatar
blueflht
and again i differ with the norm, call firecap501 for the arec audio setup. tell him blue sent you
Old Dec 1, 2008 | 06:48 PM
HarryDavidson's Avatar
HarryDavidson
What a surprise...the guy asks for a product that Firecap doesn't offer but he still plugs him. Blue, you're like a broken record...I hope you get a good kickback from Firecap for all the spam you spread.
Harry
Old Dec 1, 2008 | 07:39 PM
mattman22033's Avatar
mattman22033
+2 for HogTunes and Pez.
Old Dec 1, 2008 | 09:33 PM
1flhtk4me's Avatar
1flhtk4me
How are you going to mount the speakers?As far as I know,Pez does not sell speaker enclosers for Road Glide lowers unless he just started to.
I'm in the process of mounting speakers to the storage boxes,1 down and 1 to go.I had them in the bottom of the boxes but found a better way to mount them on the front.
Old Dec 2, 2008 | 06:39 AM
Sincecrazy's Avatar
Sincecrazy
Im building some speaker mounts out of fiberglass that will bolt in to where the glove box does. It will hold a 6.5" speaker and measure roughly 8.5" down from the top of the fairing lower to clear the snap in vents I have. Ive finished the plugs, now Im working on making the molds. Ive had some request from forum members, and plans are to produce some. Heres a link to my previous bike and the radio I made for it.
https://www.hdforums.com/forum/touri...-roadking.html
Old Dec 3, 2008 | 12:25 PM
Sincecrazy's Avatar
Sincecrazy
I finally got some info from the dealership. The HK radio is a four channel radio and has two output plugs at the back of it. One of the plugs drives/controls the rear speakers as mounted on an ultra. Does anyone know of the plug numbers from the back of this plug that drive the rear speakers?
Old Dec 3, 2008 | 12:56 PM
Thirdup's Avatar
Thirdup
Aren't Roadglide lowers are a totally different designed than batwing lowers? The face of the EG lowers sweeps forward ...where the RG's sweep aft (plus the glove boxes are sideways).....at least on the older style. So I don't know if a speaker mount like the one from Hog Tunes would even come close to fitting. I don't recall ever seeing any production speaker pods being sold specifically for the RG lowers, but there is a member who was working on RG pods and was thinking about producing them.
https://www.hdforums.com/forum/touri...aker-pods.html
