Wobbly Adj. rider backrest....
Old Dec 2, 2008 | 05:50 PM
Learjet's Avatar
Learjet
Stage IV
Default Wobbly Adj. rider backrest....
I just installed an 09 adj. rider backrest on my 08 RKC and it seems to wobble everywhich direction right where it is adjustable (up and down adjustability close to the pad).
Is this normal? Can you fix it where it doesnt wobble. I understand that when you start riding, it doesnt really move that much with your back resting against it, but I would rather have something a little more stable.
Thanks,
John
Old Dec 2, 2008 | 05:53 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Thanks,
John
Mine does the same. Once pressure is against it, it's pretty stable.
Old Dec 2, 2008 | 05:55 PM
ybnorml's Avatar
ybnorml
Are '09 accessories compatable with the '08 models ??
Maybe you need an '08 adjustable riders backrest for your '08 scoot....
Old Dec 2, 2008 | 06:10 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Nothing to do with it...The mount is secure (will not pull out) but does move around alot without any back pressure on it.
Old Dec 2, 2008 | 06:31 PM
ybnorml's Avatar
ybnorml
ok...misread misunderstood the trouble
Old Dec 2, 2008 | 07:21 PM
gunner11's Avatar
gunner11
Just put you a hot woman back there, problem solved!
Old Dec 3, 2008 | 06:49 AM
mrsr71's Avatar
mrsr71
Mine is the same way, they’re designed that way
Old Dec 3, 2008 | 01:55 PM
yota's Avatar
yota
Default What I did
Mine was quite loose and I took a zip strap, cut it off to be say 1 inch long and I slid it along the side of the backrest stem and it felped snug things up some. If you look thru the seat opening you will see how much room there is to wedge something in..May even have room for one on each side..
Old Dec 3, 2008 | 02:50 PM
HDRider2002's Avatar
HDRider2002
I can see your concern, its not like everything else on these bikes shake or anything?
Old Dec 3, 2008 | 03:35 PM
Learjet's Avatar
Learjet
Stage IV
Ok, figured. Thats what ill do.
I would think theyd come with something a little more less wobbly than what theyve got.
