OK, I'm Pissed, I Need Help
Old Dec 10, 2008 | 03:18 PM
  #31
russl179's Avatar
russl179
Originally Posted by buckmc
Hey Russ,something you can do to increase hp,and pull is take your spark plug's check the gap,mark your plug opposite from the gap,then when you put them back in turn your gap directly to your valve's,can tell the difference right away.If you haven't looked into big city thunder,they have a lollipop,restrictor that will give you much more pulling torque,and they are not that expensive,check it out. Both do great on my 2001 FLHT.
About what I can expext from a person from Louisiana. ;-)
Old Dec 10, 2008 | 03:29 PM
  #32
russl179's Avatar
russl179
Originally Posted by Texas Fat Boy
Okay I need 2 things:
1) Some pictures of your bike
and
2) A list of what you have already done.
Then I'll know how to help.
Just listing everything you've done might keep you busy for a little while anyway.
No particular order:
Kury Turn Down Style Heel Guard-Right Side
HD Braided Stainless Steel Fuel Line Crossover
HD Logo Front Fender Skirt
HD Engine/Transmission Interface and Top Cover
HD Tour-Pak Side Marker Lights
HD Chrome Regulator Cover
HD Tank Bra
HD Chrome/Rubber Rider/Passenger Floorboards
HD CHrome/Rubber Hand Grips
HD Chrome/Rubber Heel/Toe Shifter Pegs
HD Chrome/Rubber Brake Pedal
Kury 9061 Extended Brake Pedal-Solid Chrome
HD Chrome Windshield Molding
HD Tour-Pak Lid Organizer
HD Tour Pak Premium Luggage Rack
HD Stainless Steel Switch Housing Hardware
HD Utility Light (Piece of S___)
HD Tour Pak Wall Orangizer
HD Air Deflector-Dark
HD Splash Shield Kit
HD Detachable Passenger Seat Hardware
HD Angled Highway Peg Mounting Kit
HD Chrome/Rubber Large Hiway Pegs
HD Chrome Footpeg Bolts
Hog Tunes Front Speakers
HD Chrome Transmission Hardware Kit
HD Instrument Gauge Cover Kit - Complete
HD Auxiliary Brake/Run/Turn Signal Conversion Kit
HD Chrome Instrument Dezel Cover Kit - Complete
HD Multi-pocket Fairing Pouch
HD License Plate Frame Kit
HD Cam Cover Chrome Hardware Kit
HD Chrome Operator Floorboard Covers
HD Rider Backrest
HD Fairing Bra
HD Saddlebag Lid Cover Kit
HD Thermometer/Clock Set w/Double Mounting Hardware
HD Front Wheel Ai Baffle Kit
HD Chrome front and back brake master cylinder CoversBrackettron XM Radio Mount
XM Roady Rain cover
Nelson Rigg GWE 1000 Touring Bag
HD Timer Cover KitHD Tail Lamp Chrome Collar Kit
HA Aluminum Shifter Linkage
HD Saddlebag Lid Trether Kit
HD Clutch Cabel Ferrule Cover and Banjo Cover
HD Mirror Extension Kit
HD EFI Fuel Fitting Cover
Mini Beast Horn
HD Throttle Cable Adjuster Covers
HD Headbolt Cover Kit
HD Trunk Mount Flag Kits - 2 HS Saddlebag Wall Organizer
2 Blueant Blue Tooth receivers/IntercomHD King TourPak Wrap Around Light Kit
HD Saddlebag Rail Bracket KitHD Dual Bulb Halogen Headlamp Kit
HD Primary Cover Hardware Kit
HD Turn Signal Trim Rings - three sets
Baggers Only Read Footboard Cover Kit
HD Passing Lamp Trim Rings
HD Touring Chrome Front Wheel Spacer Kit
HD Read Fender Rail Insert
HD Front Axler Cap Nut Kit
HD Front Fender Rail Insert
HD Radio and Gauge Facetrim
HD Front Speaker Trim
HD Radio Faceplate TrimHD Chrome Front Brake Rotor Hardware Kit
HD Wind Deflector Kit-Chrome
Ride Time front and back fender tip led light boardsHD Custom Hand Lever Kit
HD Supplementary 12 Volt Power Source
HD Chrome Lifter Block Cover
HD EFI Untake Manifold Cover
HD Billet Clutch Cable Adjuster Cover
HD 1 1/4" Cable Clamp
HD Two-into-one Wiring Harness Adapter
HD Chrome License Plate Bracket/Taillight Kit
HD Cylinder Base Cover
Mean City Cycles Seat Redo
HD Left and Right Saddlebag Guard Bags
HD Nostalgic Bar and Shield Air Cleaner Cover
Lyndall Brake Pads-front and rear
AMS OIL in tranny and engine
HD Chrome Front Caliber Chrome Cover Kit X2
HD Fuel Console Door-HD Logo engraved
HD Mid Frame Heat Deflectors (PO S___)
HD Soft Lowers
HD Mirror Extensions
HD Clear Fender Tip Lights Covers
HD Front Caliper Inserts
HD Front Axle Nut Covers
HD Front Fairing Bra
HS Chrome Solenoid Cover
HD Chrome Derby Cover Screws
Appropriate Hot Toppers scattered throughout the bike
HD tour pak chrome rail
HD under the tour pak chrome auxiliary brake light kit
Old Dec 10, 2008 | 04:31 PM
  #33
mrsr71's Avatar
mrsr71
HD Tank Bra
HD Rider Backrest
HD Fairing Bra
XM Roady Rain cover
Mini Beast Horn
HD Soft Lowers
Come-on...is that all
Old Dec 10, 2008 | 05:27 PM
  #34
cfmii11's Avatar
cfmii11
This post is useless without pictures!!!
Old Dec 10, 2008 | 08:03 PM
  #35
notlost_nc's Avatar
notlost_nc
That's quite a list of bling. It's a shame it's so slow
Old Dec 10, 2008 | 08:55 PM
  #36
will2002's Avatar
will2002
I aint never seen a bike with that MUCH bling on it. Pics PLEASE!!!!
Old Dec 10, 2008 | 09:02 PM
  #37
qtrracer's Avatar
qtrracer
Cool
Ok now replace muffler bearings and rotate the air in the tires and you are set!!!
Old Dec 10, 2008 | 11:16 PM
  #38
gregm's Avatar
gregm
Here's something you could do, send me all the removed O.E.M. parts. That way you would have more room to work on your next project. Just tryin' to help........
Gregm
Old Dec 11, 2008 | 06:19 AM
  #39
russl179's Avatar
russl179
The muffler bearings are made of chromiumoxidenitratemonosodiumsplenda.
Old Dec 11, 2008 | 07:25 AM
  #40
russl179's Avatar
russl179
