Fairing lowers install help
Old Dec 17, 2008 | 11:25 PM
Texas Fat Boy's Avatar
Texas Fat Boy
Originally Posted by Monstermile
Done deal. Did it my way and got it. Pulled the lowers off and took a big screwdriver and gave the clamp a couple of good cranks and that is all she wrote. Obviously the other side took a matter of minutes to install.
Just "go with the flow man" don't force it. Waaaa hahahahah
I'm glad you got it worked out.
Old Dec 18, 2008 | 06:56 AM
Harleypingman's Avatar
Harleypingman
Curious; which side gave you trouble?
Old Dec 18, 2008 | 08:50 AM
Garemlin's Avatar
Garemlin
I started with the right side. Can't say as far as the clamps were concerned the side would have mattered. But the left side lower does not seem like it wants to fit correctly.
Old Dec 18, 2008 | 08:53 AM
Phurion's Avatar
Phurion
Originally Posted by 1FLTRI4ME
Channel Locks work good.Also if the holes are somewhat close,you can thread the bolt and it will catch the second hole.
+1
I loosely attached the top bolts so I could move the bottom around and see how the bottom clamp would "sit" on the engine guard and how the lowers would rest on the clamp, then removed the lowers and used a pair of goose-neck pliers to "bend" them into a more friendly position so they'd line up better. Bolts slid right in, no hassle.
rattracer
May 14, 2016 03:49 PM
creep1
Mar 25, 2009 03:48 PM
dlowder
Feb 2, 2009 11:13 AM
shortleg
May 30, 2008 03:07 AM
bdjhog
Sep 20, 2006 01:49 AM
