Wiring up a Brake Light Modulator
Old Dec 18, 2008 | 02:25 PM
3/4 life crisis's Avatar
3/4 life crisis
Default Wiring up a Brake Light Modulator
Hello all,
2008 Street Glide. Can anyone tell me what color wire(s) do I cut to wire in a brake light modulator? I had one on my 07 Sportster, really like that feature, but I traded the bike in.
If I remember correctly is only one wire needs to be cut to wire the modulator in series. Don't have a service manual yet, is on order.
Thanks in advance.
Old Dec 18, 2008 | 06:03 PM
skratch's Avatar
skratch
depends on the modulator i guess, i know there are some that are plug and play and don't require any cutting.
if you are supposed to splice into the hot wire for the brake light, in my manual, it specifies the r/y wire as the brake. this is for an 07.
Old Dec 18, 2008 | 06:05 PM
leeinmemphis's Avatar
leeinmemphis
why not just buy a Kisan bulb with one built in?
Old Dec 18, 2008 | 06:27 PM
Skivvy9r's Avatar
Skivvy9r
Skratch has it right; '08 is the same as an '07. Rear brake light is the R/Y wire.
Old Dec 19, 2008 | 11:24 PM
3/4 life crisis
Considered that route. Had a "Back-Off"(?) modulator on my previous ride for over a year without problems. Figure might as well stay with the proven. Hate to have to change bulb if it burns out and have to order it. I double sided taped and lightly siliconed the modulator behind the fender on my Sportster. Was running 11" Progressive shocks, no rubbing.
And thanks for the color code. Ride safe!
Old Dec 20, 2008 | 12:12 AM
DZLDR's Avatar
DZLDR
if you have a test light, remove your seat and find the plug in connector harness that goes to the rear. It usualy sits right on top of the rear fender under the seat. Un plug it, turn the key on, and find which terminal is hot. That one IS NOT the one you want, that one is your running light circuit. Now press down on your foot brake or hand brake. The one that lights the test light now IS the wire you are looking for.
Old Dec 20, 2008 | 08:11 AM
3/4 life crisis
Great idea, thanks! I never thought of wiring it under the seat, probably better than "gluing" it under the fender. Now I just need to find my testlight..... Or maybe is the same color wire that goes to the brake light. See if I get lucky
Old Dec 20, 2008 | 10:46 AM
whoop72's Avatar
whoop72
on my rg, I put it under the left side main fuse cover, running the ground to the battery. simple and out of the way.
Bubseth
Electrical/Lighting/Alarm
13
Jun 15, 2017 10:27 AM
emperor wurm
May 21, 2012 03:58 PM
s.ga.rider
Aug 18, 2011 07:46 PM
Gregte
May 19, 2008 07:39 PM
dr.jim
Aug 24, 2007 10:53 PM
