Axle cam adjuster freeplay?
Old Dec 21, 2008 | 02:44 PM
SteveB FLH's Avatar
SteveB FLH
Default Axle cam adjuster freeplay?
I have been having a problem keeping the axle cone nut side cam adjuster from slipping while trying to torque axle nut to spec's. Tried a couple of times can't keep the cam tight against weldment. Noticed that the adjuster had about 1/16" free play on axle, never noticed this before, but when I took rear tire off noticed that the belt tension was not as tight. Any one had a similar problem? AND if you did How did you solve it?
Old Dec 21, 2008 | 03:21 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Tap the shifter side cone nut with a rubber hammer to assure it's seated tight against the frame. Using an large adjustable wrench or the proper size wrench for the nut, hold the nut while torquing the other side or Tip- Tighten-up the brake side nut so it's fairly tight against the adjuster but where you can still adjust the belt tension from the cone nut side. When you go to tighten the nut, it may not move at all. That has been my experience anyway.....
hdfatbob12
Jan 3, 2024 10:52 PM
sweet07
Mar 10, 2020 02:01 PM
3itodd
Sep 26, 2012 07:50 AM
SteveB FLH
Mar 16, 2011 12:03 PM
Kaycee
Apr 21, 2010 08:04 PM
