Primary leak
Old Apr 11, 2006 | 04:20 PM
blukrom's Avatar
blukrom
Default Primary leak
I posted this on another form but got no response so I thought I might try it over here.
I have and 05 RK custom and installed the HD automatic primary adjuster a few weeks ago. I used a brand new HD gasket (cleaned all the surfaces) and torqued everything to the harley specs using the pattern specified in the manual. Now I notice that its wet under the area where the clutch lives and Im getting a silver dollar sized oil mark on the floor. What the heck???? Help? Can anyone offer any advice?
thanks.
Old Apr 11, 2006 | 04:36 PM
Kahuna's Avatar
Kahuna
Default RE: Primary leak
Could be one of two things:
- Your Derby cover gasket is pinched!
- Your Primary Shaft Seal is leaking.
If it didn't leak until after your part installation, I would think the Derby cover seal is the culprit. I would check the gasket for cuts or pinched areas. However, the shaft seal leak is pretty common.
ORIGINAL: blukrom
thanks.
Old Apr 11, 2006 | 06:06 PM
ricoman's Avatar
ricoman
did you put a new o-ring on the primary drain plug? and torque it to spec?
Old Apr 11, 2006 | 11:45 PM
blukrom's Avatar
blukrom
Thanks for the replys.
I did take take extra care not to damage the derby cover gasket and I dont feel any oil around it. So I think that part is okay.
But regarding the drain plug I didnt change the o ring, but Im pretty sure I torqued it. I will need to go check it though now that you mentioned it.
Thanks
Old Apr 11, 2006 | 11:50 PM
CharlieZ's Avatar
CharlieZ
Had my Primary Shaft Seal replaced under warranty on my 05 Road King today.
Old Apr 11, 2006 | 11:54 PM
blukrom's Avatar
blukrom
I dont think its the shaft seal because it ws fine before I opened it up. But you never know It could have gone bad at the same time. I hope not but I will check it as well.
Old Apr 12, 2006 | 01:13 PM
navyman's Avatar
navyman
I put some thread sealer on the drain plug threads when I reinstalled mine. No leaks. I noticed my dealer does this also.
Old Apr 13, 2006 | 03:17 AM
98kingflh's Avatar
98kingflh
Did the same install on mine, and guess what. Leaked, I could not get it to stop. So I double checked everything and finally realized that Harley had replaced the rubber O-ring years back with the paper gasket. The parts guy at the local HD parts department also said to check the cover to make sure it had not been over torqued and out of whack?? It's possible. So now it has a 2 dollar o-ring like they used too have plus it has the paper gasket like they put in now. No leaks, no drips, no runs. It was also the perfect time for me to change out to Mobil one synthetic, so why not.
Henry89
Mar 1, 2016 03:26 PM
don g
Nov 20, 2011 10:46 AM
BiggestDawg
Oct 28, 2010 06:26 PM
Helitrash
Jul 31, 2008 10:04 AM
blukrom
Apr 12, 2006 10:10 PM
