Pike's Peak
Old Dec 23, 2008 | 09:16 PM
09RKC's Avatar
09RKC
Default Pike's Peak
At 14,100 ft asl, will a 2009 RKC make it up there? I drove a '79 MBG to the top years ago and was funny... as I crested the last knoll starting the slow downhill roll to the Welcome Center the car said "ENOUGH!" and died . And interesting how many stops you have to make in descent at brake checkpoints. I was in good shape all the way.
Anyway, will I have problems in taking the bike up there?
Old Dec 23, 2008 | 09:35 PM
Clint55's Avatar
Clint55
Don't know. But if you have a programmable EFI manager like a PCIII, you could probably load up a custom map for the climb.
I was stationed at Pete Field in Co. Springs for 3 years from 73 to 77. Rode my Kawi 750 Triple 2 Stroke (Purple) up Pikes once and actually had to walk along side it for the last 1/2 mile. It had a little power but not enough with me on it.
Old Dec 23, 2008 | 10:04 PM
nocarb's Avatar
nocarb
My 02 Ultra made it with no problems.
Old Dec 23, 2008 | 10:25 PM
Texas Fat Boy's Avatar
Texas Fat Boy
In 1980 I road a Kawasaki 1000 LTD (the 1st Kawasaki that was a semi-Harley style) up and down with no problems what so ever.
I understand it is now almost all pavement. In 1980 the top half of the mountain road was gravel. I almost lost it on one curve coming down a little to fast. Me and my buddy were passing cars going up the top half though. Electronic ignition is awesome.
Old Dec 23, 2008 | 10:38 PM
Northside's Avatar
Northside
Should make it no sweat. You'll notice an extreme loss of power but you should be fine. There used to be a motorcycle race up Pikes Peak. An old brother from the club won it back in the 50's. Sadly he died in the spring of '07.
Old Dec 24, 2008 | 04:55 AM
cookiemech's Avatar
cookiemech
Your '09 RKC is so much more technically advanced than a '79 MGB that it's not funny. The new bike has oxygen sensors and thus closed-loop feedback to the fuel injection, so that it will maintain the same air/fuel ratio at the top of the mountain as the bottom (certainly not true with the carburetor on the MGB; you would have been way richer at the top than at the bottom, which is likely why it stalled.)
Of course, as someone mentioned, you will have significantly less power at the top than at the bottom, since there's just not as much oxygen at the top. The bike will have a lot less trouble breathing than you will.
Old Dec 24, 2008 | 05:01 AM
jpooch00's Avatar
jpooch00
My '03 RK carbureted model had no problem whatsoever. Your more advanced EFI bike should do even better. Remember to tale some cold weather gear. It can snow up there in July!
Enjoy your trip and ride safe,
John
Old Dec 24, 2008 | 05:07 AM
nolafishr's Avatar
nolafishr
You should not have any problems, I was there last year and had all kind of vehicles there and did not see any break downs, on the way down there is a check point where they take the Temperature of your Brakes to see if they are over heating, if so they make you pull off and let them cool down for safety reasons. It is Beautiful Country there and remember the Higher you go the Thinner the Air Gets! I have never been that High Before! LOL
Old Dec 24, 2008 | 06:05 AM
2Sore's Avatar
2Sore
Mt. Evans about a hour west of Denver is a hundred feet higher then PP. All blacktop. Had my '90 Dresser (carbed) up there without any problems back in '91. Like others said, dress warm..it was 34° at the top in July.
Old Dec 24, 2008 | 10:32 AM
johnu's Avatar
johnu
Oh, I though you meant Pike's Peak in Iowa!
http://www.igsb.uiowa.edu/Browse/Pik...state_park.htm
