opening the batwing
Old Dec 25, 2008 | 05:09 AM
shekmark's Avatar
shekmark
Default opening the batwing
I've never done this , but want to install an antenna and garage opener. Is the batwing easy to work on? Any helpful hints needed? Thanks
Old Dec 25, 2008 | 05:36 AM
Glideguy08's Avatar
Glideguy08
It's easy just make sure you cover up your front fender and follow your manual.
Old Dec 25, 2008 | 05:44 AM
HDUltraRider's Avatar
HDUltraRider
Very very easy four screws on the inside and the four holding the windshield.... follow the manual and remember to loosen and tighten evenly when doing the inside screws.
Old Dec 25, 2008 | 06:40 AM
honestbob's Avatar
honestbob
Take the windshield off first! The first time I did mine It dropped and got scratched.
Old Dec 25, 2008 | 07:03 AM
bdp's Avatar
bdp
You will have to steer hard left and hard right to get to the two inside screws
Old Dec 25, 2008 | 07:09 AM
Whatyardwork's Avatar
Whatyardwork
Very easy to remove.I believe there are only 7 screws holding it on..A couple of tips:
1.Make sure you use the proper torx bit, a T25 may seem to fit when a T27 is required.Using a sloppy torx will round out your screws making for future problems.
2.A second set of hands is nice when removing the last screw holding the windscreen.
3.When re attaching the fairing, tighten the middle windscreen screw first to avoid un needed preasure on the fairing {do not over tighten}.If you dont have a magnetic torx bit a piece of tape inserted into the screw head will give you a secure fit between the tool and the screw.The 2 lower screws are difficult to reach with your fingers, the tape will lock the screw to the bit.
4.Install all of the screws loose before tightening anything.There is a seal between the inner and outer fairing.By taking your time and paying attention to this seal as you alternate tightening the screws you will be doing yourself a huge favor by preventing water from entering the fairing.
Old Dec 25, 2008 | 07:18 AM
gregory1's Avatar
gregory1
what brands of antenna and opener are you installing?
Thanks
Old Dec 25, 2008 | 07:31 AM
nvsteve's Avatar
nvsteve
Put some old socks on the passing lights to prevent scratching fairing when removing.
Old Dec 25, 2008 | 08:14 AM
dawg's Avatar
dawg
Click HERE
Old Dec 25, 2008 | 08:18 AM
HDV-GLIDE's Avatar
HDV-GLIDE
I'm surprised no one mentioned......
Remove the windshield first but after it's removed, re-insert the middle screw a few turns to hold the fairing in place while you remove the inner fairing screws.
Now holding the fairing from below the headlight, remove that one screw and pull the fairing towards you until you can see the connector for the headlight. Reach in, unplug it and the fairing is free. Make sure you have a safe area to place the fairing after it's removed.
