When I had the 95 C.I. and S&S 510G cams installed the dealer remapped the bike .It runs great but would there be any benefits to installing a P.C. III and is there a good place in northern Michigan with a dyno. Thanks.
Sorry I mean they recalibrated the ECM. It only pops once in a great while. Just wondering what the benefits would be with the P.C. III. Must of been the Bud lights last night.
How did they recalibrate the ECM? The answer (same as for the first time I asked this, only differently [tried to use the same language you did each time]) about what a PC-III might bring to the table for you depends on what you're already using. If you remapped the ECM directly, then you likely already have a far better tool than any Power Commander.
Its sounds like you are trying to say they did a download to the stock ECM right? From what you are posting you do not have a SERT? If you do not have a SERT then a PC3 with a good tune would be much better then a Factory Download to the stock ECM.(My opinion)
You can not make changes to the stock ECM unless you have a SERT.
