Wheeldock Problem
Old Dec 31, 2008 | 04:09 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
put mine on yesterday pita the made in china nut with welded on lacating washer fell off there was no penetration on the weld but i adapted and now that its on it works as advertised.
Old Dec 31, 2008 | 04:34 PM
dgoodbmw's Avatar
dgoodbmw
Default no fear
I suggest you call Rod and co. and ask them to send you a different version, (height). I had to go thru 3 stands b4 i got the right one that enabled the bike to almost roll onto the stand. They have several diff. height units, and im sure they will help you.
Old Dec 31, 2008 | 04:51 PM
TheShrink's Avatar
TheShrink
If you always park the machine with the front tire up, (uphill), you will never have any troubles. This goes for center stand or not.
Old Dec 31, 2008 | 05:07 PM
bjryman's Avatar
bjryman
Default Thanks
Thanks everybody. Lot's of ideas, and at least one other as weak as me!
I hadn't thought about contacting the vendor since I have the stock Ultra and thought that the basic unit was fit for it. Perhaps they did send one a bit different. I'm going to measure the difference in height also to see how much difference there is
I'm not giving up, but do look quite stupid with my one leg on the center stand peg, sweating like a beast and my wife LOL.
Oh BTW, during the last year I lost 50 lbs to get to my current weight..ain't going back for nuthin
Deepsouth251's Avatar
Deepsouth251
I'm 6'4" 275 lbs and find that while sitting on the ultra I have trouble applying enough weight directly in the center of the lift handle, it appears the handle is kind off far back to do easily from the dvr seat. I have better luck putting it up while standing beside it. I can then apply weight straight down with very little effort. Love my wheeldock stand, for lots of different reasons, easy fluid changes with no jack, bike stands straight up, takes up less room in garage, good investment.
Old Dec 31, 2008 | 06:10 PM
ezriderpgh's Avatar
ezriderpgh
Originally Posted by BCguy
No, it ain't just you. There is no way that I can get my RG up on the stand while I'm straddling the bike nor can I get it up on the plywood either. I've tried many times and it just won't go with my weight (165lbs) on the lever. I think you need to be in the 200+ range to get this to work.
Still, I like the stand and it works fine for me while standing beside the bike.
I am 260 and can not get it up while straddling the bike. I must get off and do it from the side and that's no picnic.
Old Dec 31, 2008 | 06:15 PM
spizzyman's Avatar
spizzyman
I had to read that twice before understanding exactly what you meant.
spiz
Old Dec 31, 2008 | 07:06 PM
BillinNY's Avatar
BillinNY
I would definitely contact the vendor. I have the Wheeldock center stand on my EGS, lowered front and rear, I'm 5"7", 155lbs and I can pull it on the stand every try, and I don't cough up a gonad while doing it. Also, if I use a 1/4" plywood slab, I can get the rear wheel to spin freely.
-Bill-
Old Dec 31, 2008 | 07:08 PM
r8rs4lf's Avatar
r8rs4lf
I don't understand what's so hard about it?
There should be no need to have to pull on anything to get it on the stand. What I do is put my foot on the lever, make sure both feet of the stand have touched down which basically centers the bike, then push down hard and up she goes. I don't pull on the bars, crash bars, anything. The key that I have found is focusing everything on that lever and pushing down hard.
Old Dec 31, 2008 | 07:12 PM
ezriderpgh's Avatar
ezriderpgh
spiz
I knew it as soon as i clicked submit but forgot to go back and fix it!
