Rear Lowering Kit
Old Dec 31, 2008 | 05:23 PM
hardyf111's Avatar
hardyf111
Default Rear Lowering Kit
I am planning to install a rear lowering kit. The instructions say to finally "torque the shock bolts to factory specifications."
So... what are the torque specs for shock bolts on a 2008 Road Glide?
Yes, I know to get a factory manual, and I will. But I still would like to know the specs now
Thanks in advance,
h
Thanks in advance.
Old Dec 31, 2008 | 07:16 PM
Kbore's Avatar
Kbore
SInce you havn't recieved any replies yet, here are the specs for an 02' Road King to maybe get you going:
Top Bolt 33-35 ft lbs
Bottom Bolt 35-40 ft lbs (Blue Loctite)
Not saying these are the factory specs for your 08 Glide, these are in the manual for '02 Road King.
Old Jan 1, 2009 | 07:33 AM
hardyf111's Avatar
hardyf111
Thanks
Old Jan 1, 2009 | 02:08 PM
JHeiser's Avatar
JHeiser
I torqued mine to 35 fts lbs top and bottom per the installion sheet that came with the lowering kit - mine is Los Angles Choppers lowering kit (bought it at J&P) installed it on my 2007 RK.
I lowered mine for the style/look (my legs are plenty long enough). Why did you decide to lower yours?
Old Jan 1, 2009 | 03:38 PM
EasternSP's Avatar
EasternSP
You probably have the air shocks on your RG. The lowering kit may cause additional wear on the shocks. I installed a lowering kit on mine and not long after, the shocks wouldn't hold air. I replaced them with the progressive 440s and removed the lowering kit. Anyway, torque would be about 35ftlbs top and bottom.
cbky71
Jan 4, 2012 09:08 AM
chriscraft280
May 2, 2011 06:57 PM
JT-FXDL
Mar 17, 2010 04:08 PM
dragpipe
Apr 23, 2009 10:59 AM
jag1886
Oct 30, 2007 02:14 PM
