True Duals Installed...SWEET!
Old Jan 2, 2009 | 06:56 PM
FX4's Avatar
FX4
Originally Posted by ezriderpgh
That wont work either because they have an indentation in them to accomodate the axle nut.
I would not run the bike until you have a set of aftermarket mufflers, they are cheap and available everywhere.
You are correct I forgot about that.
Old Jan 2, 2009 | 07:05 PM
skunk237's Avatar
skunk237
Originally Posted by garyhendley
i went with the fullsac and se mufflers great sound get compliments all the time
they sound deep-ride safe
Did you notice a drop in your low end torque when you went to the fulsac duals??/
Old Jan 2, 2009 | 07:11 PM
Jerry/MD's Avatar
Jerry/MD
Originally Posted by papifun
jerry u can also push through a stick or measuring tape and u will see the differance from each side.
I checked them out with a flashlight. Sure enough...BIG difference. The left side is obstructed while the right side is open down the middle. Funny, when running you can't tell a difference.
Looks like I will be ordering a new set of mufflers ASAP. Thanks for the info...all of you.
Old Jan 2, 2009 | 07:15 PM
skunk237's Avatar
skunk237
Originally Posted by Jerry/MD
Got V&H True Dual headpipes installed on my '08 FLHTC. Stuck with the stock HD mufflers...for now. Gotta say, it sounds pretty sweet.
I noticed it runs just fine...no change done to ECM. My local dealer had warned me there would be some sputtering, mis-firing, etc without a new download. Bad info?
Jerry,
I have a almost brand new set of Vance & Hines Classics that have 100 miles on them I bought for my 2007 Ultra,,, I loved them... Wife said they were to loud !!!!..... She Won and I put on SE Touring mufflers.... If interested PM me and we can talk price... I am located over in Penna just north of Pittsburgh...
Old Jan 2, 2009 | 10:44 PM
glens's Avatar
glens
I don't know exactly what was done when with the mufflers, but from '07 'til now, the left side is an open chamber with some insulation screened-in around the perimeter. The outlet is a pipe maybe 8" long, closed on the inner end (folded over) and with about a dozen pea-sized holes punched/drilled into it.
At idle, the flow is different side-to-side with the prior touring exhaust as witnessed during warmup from a cold start on a cold morning, if no other way. At any time at (not hot) idle you can seal off the left muffler with the palm of your hand with little effect on the engine (mainly affecting the sound). Doing so on the right quickly chokes down the engine.
I surmise that even though a hand a few inches behind the muffler feels rather like the flow is the same at idle, once the gases get moving "for real" the left muffler falls behind the right in flow capability. It certainly differs in flow qualities over various rpm.
Old Jan 3, 2009 | 08:18 AM
Jerry/MD's Avatar
Jerry/MD
Two riders I know have '03 EG Classics. Apparently, the mufflers on their bikes differ greatly from mine. It was based on their experience (one installed true dual headers and kept the stock mufflers) that I THOUGHT I could re-use the stock units. Bad assumption on my part.
Once again, thanks for all the valuable info.
Old Jan 3, 2009 | 08:42 AM
katobird's Avatar
katobird
Mine is running great with stock mufflers, but they are "cored-out"....
slimjim1976
Apr 22, 2014 08:16 AM
hubble
Apr 22, 2010 03:52 AM
MyFirstHD
Jul 12, 2009 03:27 PM
rickoshay45
Sep 5, 2007 08:20 AM
tmaxx
Dec 1, 2006 01:13 AM
