Stripped screw
Old Jan 3, 2009 | 11:37 AM
1flhtk4me's Avatar
1flhtk4me
Originally Posted by leon anthony
why not just tap it out to the next size up I don't think it would show up bad
It would show up because of the larger screw,plus a larger clearance hole is needed.
I would also go with the thread insert.
Old Jan 3, 2009 | 01:48 PM
DrPlastic's Avatar
DrPlastic
I don't know what all the hullabaloo is all about!
Helicoils are used on every acft structural and power train system in the world. If it is good enough for the Space Shuttle than it is good enough to use on my scoot! I use them all the time at work. Takes all of 5-10 minutes to install and the threads will last 200 times longer than the aluminum threads in the aluminum case.
Old Jan 3, 2009 | 02:24 PM
robbie52's Avatar
robbie52
Hafta agree. Helicoils are better than orignal aluminum threads. In some cases, helicoils are inserted in auliminum cases by the manufacturer because they are stronger.
Old Jan 3, 2009 | 03:25 PM
dgriffith's Avatar
dgriffith
In the Industrial world, there is a compound called Devcon. Sort of like jb weld. Works like it but a lot stronger. It can be drilled and tapped. Another idea.
Old Jan 3, 2009 | 10:38 PM
Chuck1's Avatar
Chuck1
Sounds easy to me, if they or the factory stripped it, then they put on a new primary cover.
Old Jan 4, 2009 | 12:34 AM
bagman1's Avatar
bagman1
+1 This stuff is awesome.
Old Jan 4, 2009 | 03:40 AM
txfxstrider's Avatar
txfxstrider
Getting off the helicoil subject, I would take it back to the last dealer that serviced it if they removed that cover. They had to know it was stripped and did not tell you or they stripped it themselves. The dealer that did the first service will probably sat that they were not the last to service it so they could not have done it.
However, either dealer may be nice enough to take care of it regardless since it is not a major deal to put in a helicoil.
Old Jan 4, 2009 | 03:57 AM
JayStronghawk's Avatar
JayStronghawk
Used Helicoil many times on the ship .. easy simple stronger... Sorry to hear about the Dealer Problems .. ever in North FL know a couple great Indy's up this way ...
Scorpio49
Oct 9, 2008 03:59 PM
gdaustin
Aug 1, 2008 12:00 PM
Chicago Spike
Aug 8, 2007 01:32 PM
goombah
Apr 6, 2007 09:21 AM
but Ill try 2 try
Jul 13, 2006 06:31 PM
