idle and speedometer HELP
Old Jan 5, 2009 | 05:45 PM
nano2424's Avatar
nano2424
6th Gear
Default idle and speedometer HELP
Hello to all. and HAPPY NEW YEAR
I need help.
I have a 2003 ROAD GLIDE. I was riding last Sunday when my bike lost idle (It will not stay running by it self ), my speedometer went to 0 and the check engine light came on . Any ideas on what can be wrong??
thanks
Old Jan 5, 2009 | 07:50 PM
*Road King*'s Avatar
*Road King*
Change your tranmission speed sensor. Allen screw on top of your tranny. Has a wire that runs up to below your seat. First remove it and clean it. It is a magnet. If that does not fix it, have it replaced. $60 or so, if my memory serves me right.
I bet your self cancelling blinkers do not work either???
Old Jan 5, 2009 | 07:57 PM
anicely's Avatar
anicely
Also heard of similar probs with the throttle positiion sensor.
Old Jan 7, 2009 | 04:55 PM
nano2424's Avatar
nano2424
6th Gear
Hello
this is what I done so far, ride it on Monday and it was working fine for the first 45 min to an hour after that it did it again so I removed the seat to check the plug for the speed sensor and it looks ok after the engine was cold toke it out again and it worked fine .
I will pull the sensor and cleaned to see what happen.
thanks to all
Old Jan 7, 2009 | 05:38 PM
dawg's Avatar
dawg
74429-97C $54.70 retail
Old Jan 7, 2009 | 08:10 PM
*Road King*
Yeah, cuz if it is acting up, cleaning it may not be a permanent solution. If you are going to go to the trouble of taking it out, may as well replace it.
eliran
Aug 17, 2014 02:54 PM
thejgw
May 15, 2008 04:58 PM
rahall
Dec 28, 2007 09:54 PM
Rocks
Dec 25, 2007 06:46 AM
Jerm21
Apr 23, 2007 05:59 PM
