Tire milage (WOW)
Old Jan 7, 2009 | 08:12 PM
NitroBerserker's Avatar
NitroBerserker
Never get over 7K-8K on rear. much better on front.
Check the air regularly 40 lbs rear, 36 lbs front
ride 2-up alot. also lot of high speed stuff.
Old Jan 7, 2009 | 09:05 PM
teqsand's Avatar
teqsand
Big Kahuna HDF Member
I got 10.5k on my stock rear and my front has 16.5 on now with a bit more to go....
2 up about 50% of the time
Old Jan 7, 2009 | 09:09 PM
RDKingRider's Avatar
RDKingRider
I heard the newer tires lasted longer, can't wait to find out
Old Jan 7, 2009 | 09:24 PM
autoxr's Avatar
autoxr
I nitro fill my tires at 40 psi...nitro psi never fluctuates more than 2 psi from cold to hot so tire wear has been impressive...dont have enough miles on the 08 to compare
Old Jan 7, 2009 | 09:46 PM
Richpend's Avatar
Richpend
I have only 3300 mil. on mine, still got a long way to go!!! It seem from what you all are saying is that the rear tire really takes a beating as compared to the front!!
Old Jan 8, 2009 | 07:00 AM
1flhtk4me's Avatar
1flhtk4me
I replaced the original rear-15700miles, front 33400.
Old Jan 8, 2009 | 07:30 AM
honestbob's Avatar
honestbob
Talking
I use a special mix, 79% nitrogen, 20% O2, and a 1% mixture of inert gasses. Seems to work real well. (hard to find though)
Old Jan 8, 2009 | 07:44 AM
timvan's Avatar
timvan
Is that a summer or winter mix? I hope its Hd aproved!
Old Jan 8, 2009 | 08:13 AM
D34's Avatar
D34
Hope I get those miles !
Old Jan 8, 2009 | 08:54 AM
Kugie's HOG's Avatar
Kugie's HOG
Originally Posted by nvsteve
Not 100% positive but I think the multi-compound tires are on the 09 wider tires.
Not the 08's.
You are correct!
