Interesting observation while idling at a stop light....
Old Jan 11, 2009 | 11:40 AM
molsen's Avatar
molsen
Sounds like electrical, either contact of a connecter, or maybe on the trans door switch. If you feel ambitious, maybe look at the speedo connector and see if any of the pins or connectors are touching.
Old Jan 11, 2009 | 11:42 AM
Geoff's Avatar
Geoff
I'll swap trannys with you and solve your problem.
Old Jan 11, 2009 | 12:30 PM
gunner11's Avatar
gunner11
Check the RPM's on the tach.
Old Jan 11, 2009 | 12:38 PM
bagman1's Avatar
bagman1
I had a similiar problem on my 07 rg especially when it was hot out. I would get the neutral light and sometimes the security light would flicker then stay on. I spoke with the dealers and they said there was an issue with the neutral switch. Even though it was under warranty the part was $18 I think and I just changed it and never had another issue.
Old Jan 11, 2009 | 12:42 PM
Skulmn's Avatar
Skulmn
Originally Posted by DrPlastic
I was in first gear idling at a stop light. While I had the clutch pulled in as I was ever so slightly letting it out the 6th gear indicator was flickering on and off. If is let it out just enough I could get it to stay on!
Hmmmmmm....
Has anyone else experienced this?
Yes I know it's under warranty so let the shop check it out. It has only happened once that I can remember so if it keeps on happening I will take it in.
Your neutral switch is going bad...Good news, it is only $18 and it is easy to replace yourself.
I chose not to go under warranty at the time and leave it at the dealer. It was cheaper to buy it and do myself.
Typically, the switch failure happens with "high heat" conditions. If it is what I say, look at the part number of the new switch and you will notice it is under it's third or fourth revision.
I have not had it fail again in almost a year....knock on wood.
Old Jan 11, 2009 | 12:44 PM
Skulmn's Avatar
Skulmn
Man............Great minds think alike
I must have been typing while you posted....
Old Jan 11, 2009 | 01:48 PM
honestbob's Avatar
honestbob
Smile
Originally Posted by RODEO
It's good practice to put her in 1st with the "clutch in" to be ready for a quick "get away" (evasive maneuver) from somone coming up from behind etc. Thats why most riders have the bike in gear. It's a smart thing to do.
Yea thanks for the advice. You are right i'm sure But I been doing this for 49 years , you know old dogs. Besides they call me HONEST Bob not SMART Bob
Old Jan 11, 2009 | 02:11 PM
Beemervet's Avatar
Beemervet
LOL And just how many of you have had to do that "evasive maneuver"? Just wait until you have a clutch cable let go when you are at a stop.
Old Jan 11, 2009 | 02:16 PM
DrPlastic's Avatar
DrPlastic
Thanks guys
I don't think I would say 45 degrees was exactly hot out but I have experienced sporadic neutral issues like up shifting into second and it going into neutral and it took a few try's to get her up into second. Plus I find it impossible sometimes to get her into neutral when stopped and have to shut her off then it going into neutral very easily. I have experienced the latter on most other bikes and chalk that up to the design of the gears and shifter dogs being loaded under RPM so I pay it no mind.
Old Jan 11, 2009 | 02:21 PM
JacktheBagger's Avatar
JacktheBagger
Anyone come up with a simple way to "know" exactly what gear you ARE in motoring down the road? I often lose track (because my mind ain't on that) and at times it would be nice to know if you were in , say 4th versus 5th or 3rd versus 4th etc.
With the six speed I keep a mental note more or less
look down doin 3000 at 60 , I know I'm in four
look down doin 3000 at 67 , I know I'm in five
look down doin 3000 at 75 or so , I know I aint commuting to work and hope I'm on the interstate
18 miles of pretty much open road to werk and I rarely get outta fourth
