Crack Headlamp...
Old Jan 12, 2009 | 08:06 AM
Master Gunny's Avatar
Master Gunny
Default Crack Headlamp...
Greeting all....
I have a cracked headlamp. It still works both on high and low beam. I am not sure if it is just the glass cover that is cracked or is this one complete unit and I have to replace the whole thing?? If so, is there a after product that will work or do I need to break open the wallet and take a bath at the HD dealer again-as always... Thanks
Semper Fi
and ride safe out there...
Old Jan 12, 2009 | 08:24 AM
jmeyer58's Avatar
jmeyer58
Should be a complete headlamp assemb, There are several aftermarket companies that make replacements, Check J&P cycles to see several and there are many more on line.
Old Jan 12, 2009 | 09:02 AM
dougbk's Avatar
dougbk
Originally Posted by Master Gunny
Greeting all....
Semper Fi
Gunny,
The lens is a housing assembly that the bulb fits into. There are some housings out there that are supposed to have better beam focus, but I haven't had enough coffee yet to recall their name.
Old Jan 12, 2009 | 09:20 AM
stevepacman's Avatar
stevepacman
Well Gunny sadly the expense part of the assembly needs to be replaced. I lost my high-beam once and thought it was a sealed beam and was looking at $95 +/- for the whole assy. Thankfully I found out the bulb was a replacement part.
Old Jan 12, 2009 | 12:46 PM
Uncle Scrooge's Avatar
Uncle Scrooge
You can get one of these aftermarket assemblies for about 1/3 the cost of the HD unit. Won't look quite as cool, but works just as well.
kew48
Mar 21, 2014 12:06 AM
knights
Apr 7, 2013 03:28 PM
tcastle64
Jul 31, 2012 07:22 PM
bberck
Jun 19, 2009 08:28 PM
SportyPig
Dec 11, 2007 06:19 AM
