Cam Chain Tensioners
Old Jan 15, 2009 | 12:25 PM
MarkM's Avatar
MarkM
My '05 Wide Glide is in the shop right now. At 33k, they took a dump. I have an extended warranty on the bike, and was told that the warranty would not cover wear replacement, but only replacement in the event of total failure. So that's what I did. Luckily I have another bike to ride while I'm waiting, but you can be sure I will have the tensioners in that bike checked when this one is done (no warranty left on the '99 RK).
Old Jan 15, 2009 | 12:53 PM
HDRider2002's Avatar
HDRider2002
Placing an order for a PCiii, then i'll get the cam i want (as well as items necessary for install, bearings etc), adjustable pushrods, and then have it all put in next year. Or, the thing will crap out and i'll have to do it sooner. I guess we'll just have to wait and see.
Old Jan 15, 2009 | 02:01 PM
jmeyer58's Avatar
jmeyer58
Had mine replaced at the dealer at 40k miles. Covered on the extended warranty as a wear item. Looking forward to another 40k then I think I will go through the entire motor and do a 95" with cams and gear drive since the warranty will be long gone.
Old Jan 15, 2009 | 02:21 PM
Cold Rider's Avatar
Cold Rider
Didn't see any mention of crank run-out. Hear this is problem on some TC 88 and 96's when going with gear drives.
Old Jan 15, 2009 | 04:28 PM
jpooch00's Avatar
jpooch00
Originally Posted by Airpump
For some reason there seems to be no set mileage pattern for the shoes to wear out. I have read threads/replies where the rear shoe had reached the metal as early as 9,000 miles. While others had gone over 50,000.
There is no doubt this was a poorly engineered design from day one. The moco should have correct this mess long before 2007, that is if the new hydraulic setup has corrected the problem.
Oh well, one could always use the moco engine overhaul program or for that matter just buy a new engine if you happen to be one of the unluckly owners. It's only money!!!
I'm NOT trying to hyjack this thread!! That said, I had not heard anything about a hydraulic cam chain tensioner till right now. Any more info would be great!
Thanks,
John
Old Jan 15, 2009 | 04:44 PM
buick455gs's Avatar
buick455gs
I changed mine at 20K miles. 2001 SERG (95 Cu In).
Both were wore out to the poin the rear one was cracked but no noise.
I installed the Andrews 37N cams with new HD 2007 cam plate, pump, inner torrington bearings, chains, Hyd. Tensioners, shims, adjustable SE pushrods.
No tuning required as I had the SE 203 cams and the 37N is the same grind.
Old Jan 15, 2009 | 05:08 PM
monkyman's Avatar
monkyman
So what did Harley change exactly that is supose to fix this on the newer years?
Old Jan 18, 2009 | 08:59 AM
st john's Avatar
st john
Default What did it cost you??
To replace your cam chain tensioners, not changeing to gear drive but just the basic
cost to replace the tensioners, with maybe adding kit # 25283-07 (thats the new
cam plate with new high flow oil pump.)
Just a pricing survey from those that may have done this.
Thanks
Old Jan 18, 2009 | 10:23 AM
1flhtk4me's Avatar
1flhtk4me
I went gear drive at 30K.The tensioners did not have much wear as far as the depth of the groove but were pitted.
Old Jan 18, 2009 | 10:51 AM
Taterdog's Avatar
Taterdog
Default Example of Worn Tensioners
Here's what my tensioners looked like at around 30k. The inner tensioner typically wears more, as mine shows. It's the one with the crack. When in doubt, have them checked and replaced or eliminated. You won't like the alternative.
BTW, I've been using synthetic oil, too. How they wear is bike specific, not a function of how you ride. Plenty has been said on this topic, so use the search feature and you'll learn more than you probably wanted to know.
Also, crank runout is important with gear drives, much less of a problem with the '99 to '01 or '02 bikes. If anyone decides to go with gears, call Andrews tech support and they can advise you accordingly.
Regardless which way you go, you can pay to have the dealer do it, but this is a job that almost all of us can do on our own. If you decide to stay with tensioners, you'll want to learn how anyway and it's relatively simple and easy. Just research it on the web and use the HD manual.
Attached Thumbnails Cam Chain Tensioners-dsc_0197a.jpg   Cam Chain Tensioners-dsc_0196b.jpg   Cam Chain Tensioners-dsc_0198a.jpg
