I thnkn of buyn ths kit shld I also buy a largr throttle body(56mm) Ill also add roller rockers and a gear driveas opposed to chain drive.ths kit shld put out major hp and tq,i wld like a cam that wld deliver more tq in the lower and mid power band where I mostly ride(3-4rpms)the 116 is probably overkill but it cost tha same to buy as a 95 H-D kit. ill put an oil cooler on it too,oh...since I wanna use the stock heads I guess I gotta get them ported to match the eng compression?(reccomend any good porters) I lv in ny n got an flhp and I no gear head all opinions welcome thnx in advance
Why not go for the overkill, then you can rebuild your drivetrain every year when you start hearing strange noises. Turn that decker into a drag bike! Big cubes deserve the biggest throttle body. A pro built stroker and throttle body will cost ya a WHOLE LOT more than a HD big bore.
looks like harley has a new SE 113 kit well bounty hunter,I guess I won't have to build that drive train every year after all. since this kit is new I gotta look into it anyone familiar with this kit yet?
Going to a real big bore that requires the machining of the engine cases is not the end of the world. That is a direction Iam thinking as I do not want to increase my stroke. 95"/98" is as far as you can go without breaking open the cases. Iam going with the biggest bore possible while leaving the stock stroke.
The longer the stroke the higher the piston speed. The higher the piston speed the faster you wear out the rings.
Not sure what kind of performance your looking for, but you will never make a rice rocket out of a Harley.............UNLESS
1) You got a ton of money
2) Don't mind a rebuild every riding season
If you answer yes to both those question, don't stop till your atleast at 124"
