This appears to be the correct unit from the picture. The number on the white label on the side should be 805-510 which is the # of the base unit. If you are using on a 07 bike you will also need the O2 sensor eliminators.
Thanks for the answer.
Are the o2 sensor eliminators something I can get from fuelmoto or... ?
Man, this whole E.F.I. thing is like learning about Harleys all over again.
