06 Ultra Engine into 03 Electra Glide
Old Jan 30, 2009 | 08:21 PM
customsoftail200's Avatar
customsoftail200
Default 06 Ultra Engine into 03 Electra Glide
Does anyone see a problem with doing this? It looks pretty straight forward other than removing the EFI for my carb.
Old Jan 30, 2009 | 09:51 PM
CrashX's Avatar
CrashX
Physically it will bolt in. If you are changing EFI out and replacing with a carb, you're going to need an intake manifold from an '06 carbed motor. The '06 has different heads than the '03, and I think that the intakes are different, if not I'm sure someone else will chime in and correct me.
Old Jan 30, 2009 | 10:26 PM
FXSTDSE2's Avatar
FXSTDSE2
The flanges: 26993-06
You will have to rejet the carb because the 06 heads breath better.
Also pull the a rocker boxes and see if the Valve seals are orange. If not, change then.
Old Jan 31, 2009 | 08:31 AM
customsoftail200
My 03 ECM should work fine right?
Old Jan 31, 2009 | 09:56 AM
FXSTDSE2's Avatar
FXSTDSE2
There is only three components on the motor. Oil pressure sender, crank position sensor and head temp sensor. Check the part #s between 03 and 06, if not the same just swap them out or change them for general principle.
Ridin the Rockies
Apr 19, 2018 09:06 PM
brinmac
May 22, 2012 07:49 PM
winchester
Jun 23, 2010 03:41 PM
Hurricane
General Topics/Tech Tips
Apr 2, 2006 09:08 PM
OH Bob
Mar 6, 2006 01:59 PM
