I use the stockers with my Fatcat. I always use the stockers. You have to make sure with the SE's that you have the pipe just right to make a good seal.
When I ordered my Fat Cat from Eastern Performance, they asked if I also wanted new gaskets and flange nuts, so I added them to the order. They sent the stock woven,tapered gaskets. I had read where there are problems getting the SE gaskets to seal, so I figured the stock ones should do the job. They are working fine. It was a PITA getting them in place, before I started to put the pipes on.
Tom
I've used the SE exhaust gaskets for years and have never had a problem, those stock gaskets will extend more than a little ways into the exhaust track.
