Hith!
Old Feb 4, 2009 | 04:41 PM
gunner11's Avatar
gunner11
Question Hith!
Can someone tell me how in the hell to get water spots off? We have hard water where I live. I rinse really good, and the blow it dry with a leaf blower afterwards, then hand dry. Even after waxing, I still see them. I use good products, but still can't seem to get them off.
I might mention my bike is Vivid Black Ultra. I know there's an expert here somewhere, thanks.
Old Feb 4, 2009 | 05:04 PM
FLoTR's Avatar
FLoTR
Not an expert on anything but if they don't come off with a cleaner/wax, sounds like acid rain to me
Old Feb 4, 2009 | 05:06 PM
FLoTR's Avatar
FLoTR
or some other acidic liquid..........
Old Feb 4, 2009 | 05:13 PM
Raaze07's Avatar
Raaze07
I use the Mr. Clean wash system for the rinse. It has a filter in it that removes the minerals from the water so you get a spot free finish. I don't typically let my bike air dry, as it takes forever when it's humid out. I use the Mr. Clean to rinse with the filtered water then blow the bike off with an electric leaf blower to remove the water from most of the cracks and crevices.
Old Feb 4, 2009 | 05:22 PM
Lincoln33's Avatar
Lincoln33
I'll second Raaze07 on the filtered water system, you might even try a water softening agent that can be mixed in small bottle and attached to your hose.
Old Feb 4, 2009 | 05:32 PM
RDKingRider's Avatar
RDKingRider
Have always used the Mr. Clean Machine, leaf blower and not a problem, even on wife's Vivid Black.
Old Feb 4, 2009 | 05:48 PM
oljim49's Avatar
oljim49
Old detailers trick.....try a little cleaning vinegar on a clean, soft cloth and then wash and put a good coat (or 2 or 3) of Rejex on it afterwards to keep it from spotting again. In extreme cases you may have to use a clay bar but the vinegar will normally take care of it. Good luck!
Old Feb 4, 2009 | 06:01 PM
sniper77's Avatar
sniper77
+1 on the vinegar. Cut it with water, 50/50 should do, and a microfiber cloth should do the trick. Don't scrub it, just let the solution do the work.
Old Feb 4, 2009 | 06:13 PM
jag1886's Avatar
jag1886
I've heard of that vinegar and water mixture working also and +1 one on the Mr Clean System.
If it's really hard water you could try some C.L.R. spot remover, just make sure you try it some where that's out of sight first, just in case.
Old Feb 4, 2009 | 06:16 PM
salty01's Avatar
salty01
www.purpleslice.com
