I see fenders lowered on stock size wheels.Are you doing anything to get a 21" to fit? stock fender and height? new fender? and is there a 21" rim that kinda matchs the stock aluminum rim (06 SG)?I know you can't see the rear much but would like a close match.Thanks.
if you just want to lower your stock fender you could look at these. If you go 21" then re drill the 2 back holes on the stock fender with a 5/16 drill bit so you can tilt the fender upward from the back. I taped a 3/8 nut to my tire and spun it for clearance and used a Metzler tire because they do not expand. You can buy a 21" fender but I didn't, if you want more clearance then buy the 21" fender. Enjoy
