roadking needs help
Old Feb 7, 2009 | 06:09 PM
harleygman's Avatar
harleygman
6th Gear
Default roadking needs help
i have a 05 king with 18,s on it and i put bidgestone tires on cause cheaper and bike started wobbling so i put metzler back on it and it still wobbles at 60 pre hour and above what can it be
Old Feb 7, 2009 | 07:03 PM
2008FLHP's Avatar
2008FLHP
balance?
Old Feb 7, 2009 | 08:13 PM
sonar_chris's Avatar
sonar_chris
Could be wheel balance, wheel bearings, wheel alignment (front or rear), neck bearing adjustment or the fork oil level. Im sure there are a few other things that I'm not thinking of.
Old Feb 7, 2009 | 08:23 PM
pigpipes's Avatar
pigpipes
If you have wire wheels, you might want to check them for trueness - those spokes will stretch and/or loosen over time.
Old Feb 7, 2009 | 08:50 PM
Berndude's Avatar
Berndude
Funny that it did not wobble with the Metler before being removed. It points first points to balance then check out the rest if you did not re balance when you put the Metzler back on.
I had a similar issue, and it was balance.
Old Feb 7, 2009 | 10:15 PM
cmose's Avatar
cmose
Could be excessive weight!!!!
Weeble Wobble
mke125125
Jun 16, 2011 12:24 PM
bouch42
Apr 25, 2011 06:04 PM
remmag
Mar 21, 2011 07:34 PM
tincup64
Oct 27, 2010 03:43 PM
qbert1963
Aug 28, 2009 07:29 AM
