CV or Mikuni
Old Feb 10, 2009 | 10:27 PM
dbarnesid's Avatar
dbarnesid
Default CV or Mikuni
I have an electra glide TC88 with a big sucker, dresser duals and Vance&Hines slash cuts. I'm running a Mikuni 42 carb. I live in Boise, Idaho which is at about 2800 feet. Sometimes I head for the mountains and go as high as 7000 feet or maybe for Hells Canyon and an altitude of about 1000.
Would the CV carb actually be a better choice since I understand it adjusts for altitude?
Suggestions most welcome.
Thanks
Old Feb 11, 2009 | 12:13 AM
Northside's Avatar
Northside
Thanks
Yeah, the CV being a vacuum slide carb theoreticly compensates some for atmospheric pressure. I live in Colorado and go from 5000+ft. where I live to 11000 ft. passes and to sea level when I go on trips. I've run both CVs and a 45m.m. Mikuni. Never had a problem with either, both great carbs! Actually I used to do California trips, over the Rockies to sea level with Bendix and Tillotsen carbs and never ran so lean at sea level, or rich on the passes, to cause a problem. I use a CV on a relatively stock motors and the more adjustable Mikuni on a seriously built motors. I know a couple of guys with 51 m.m. CVs on hot motors and they run very well. Watch you plugs and I'll bet you'll see that Mikuni is just fine. The theories you read are one thing, reality often is something else.
Old Feb 11, 2009 | 12:25 AM
IdaSpudSG's Avatar
IdaSpudSG
My son had a HSR 42 on his Road King when he lived in Boise, rode it all over the state, California at sea level and all over Colorado and Arizona when he lived there. Woked great everywhere. He replaced the CV with the Mikuni after our Sturgis trip in '99 when the CV ran like crap. The Mikuni works better for both stock and built motors has better throttle response and makes more torque than a CV on the dyno.
Old Feb 11, 2009 | 09:25 AM
buckmc's Avatar
buckmc
Spring is coming! I personally like the CV,have done alot of work on mine,and they run good when you get your jetting right.If you have a plug in your CV where you adjust the air/fuel mixture,it's been worth it (in my case) to remove and replace the air/fuel mixture screw,with a adjustable thumb screw.It help's to get it just where you want it,and they all adjust to a different point,depending on what jetting and all that's in it,but that being said they are both great carb's,much much better the Harley Used to use on shovel's
Old Feb 11, 2009 | 06:42 PM
jag1886's Avatar
jag1886
I also live in Boise and would have to vote for the CV, the Mikuni sounds racier because it has great throttle responce when you crack the throttle, but they are a pain in the rearend to work on especially in Boise because parts are very difficult to come by and no one here works on them.
I love the CV on my Sportster you can ride it any where and it always runs the same.
Old Feb 11, 2009 | 07:06 PM
harley-jones's Avatar
harley-jones
On my 1999 Fatboy Evo I changed from a CV to a Mikuni. Mikuni worked much better for me.
Old Feb 12, 2009 | 07:48 PM
dbarnesid's Avatar
dbarnesid
Default Great Discussion
Thanks for the ideas. I modified my Mikuni using the Joe Minton (American Rider Mag.) and went with a larger squirter and squirter adjustment, larger diameter needle, and much smaller pilot. In fact, I'm now running a 15 pilot which is even smaller than Joe's recommended 17.5. I got the 15 when I ordered the carb parts from the Chicago supplier. Without going to the 15 there was nothing I could do to adjust air/fuel at all. There was no rpm difference no matter what I did with the adjustment screw. The bike seems to run REALLY well now but I've only had her out a couple of times since I put on the dresser duals. It's too dang cold!!
Before I did the Minton mods I was getting about 35 mpg highway, now I get about 42. Much better... and better range for the road too!
Last summer I rode to the top of Bogus Basin Road (7,000 ft) and the bike choked to death on the rich mixture. I had to coast down the hill a bit on the way home before she would start.
I think I'll stick with the Mikuni for now... but if I keep having problems I may need to see if I can trade someone.
0maha
EVO
44
Aug 25, 2015 12:10 PM
Hank Johnson
Jun 13, 2013 09:38 PM
tom lipke
Mar 19, 2012 01:31 PM
ned120
Exhaust System Topics
Mar 2, 2008 01:05 PM
Tucker99
EVO
Dec 1, 2006 04:40 AM
