Bagger Nation PYO Monkey Bars
Old Apr 3, 2009 | 12:12 PM
  #51
Bigstick's Avatar
Bigstick
Yes there is a GOD! My parts guy called me today letting me know that my bars were shipped out yesterday! WOOHOO!!!! I will be sure to post yet another pic of these badass bars when I get them on. Till then ride hard!
Old Apr 10, 2009 | 09:25 AM
  #52
Bigstick's Avatar
Bigstick
I have everything on except the cables they are supposed to be hear today!!! By the way it only took me about 10 minutes tops per side to pull the wires through. I used a heavy duty extra long zip tie so it would be flexible. Once through the bars I taped the wires not all at the same spot, but I folded the connectors down in different lengths. I also pre-bent them while taping to make the tight turn. I used spray silicone for rubber seals to lubricate them. Worked like a charm!
Old Apr 10, 2009 | 04:03 PM
  #53
Bigstick's Avatar
Bigstick
Also for those of you thinking about doing this you will want +6 on idle/throttle and brake and +8 on clutch. +6 will work on the clutch cable but gets very tight on right fork lock no matter how you route it. I would have returned mine for a +8 but I scarred the teflon coating so I was screwed.
Old Apr 10, 2009 | 09:28 PM
  #54
BadPiggy's Avatar
BadPiggy
Did you extend the wires any?
My bars came in yesterday (Thursday).
Haven't touched them.
Took them out of the box, looked at them, threw them back in the box.
Work (self employed) has me slammed.
Old Apr 12, 2009 | 10:11 AM
  #55
obnoxs's Avatar
obnoxs
HI your bars are sick! Love me. I have a flhx, I want some similar but only 11" high and fit flhx. raw or powder coated black.
Cheers, PAtrick
Old Apr 13, 2009 | 06:03 AM
  #56
BadX's Avatar
BadX
Lets see some pictures of all these new bars
Old Apr 13, 2009 | 10:03 AM
  #57
assassin307's Avatar
assassin307
I had my PY Monkey Bars installed last week. I love them; very cool looking and comfortable to ride with. I got the kit that came with all the wire and cable extensions.
Old Apr 13, 2009 | 11:18 AM
  #58
Bigstick's Avatar
Bigstick
I am still waiting to complete the job for pics. My cables came in Friday and the upper brake line was black pearl instead of sterling chromite so we had to reorder those. They should be in today or tomorrow. I did not have to extend the wires just relocate the plug.
Old Apr 13, 2009 | 09:26 PM
  #59
yelowdog's Avatar
yelowdog
I second on the + 8 clutch and the brake cables Went with the black pear my self just rerout the conectors to under the radio 10 min a side unless TBW that took a while have a plastic conector with wires to pass around the corner lots of lube & a beer and pull both sets together welding wire works great also shrink tube on tbw conector just to be safe
Old Apr 13, 2009 | 09:50 PM
  #60
Gtsdesigns's Avatar
Gtsdesigns
agreed
didnt need to extend the factory wires, just relocate the plug to under the radio
and the left side took about 10 minutes, throttle side took forever, cause of the tbw
