Did the heim joint shift linkage mod today...
Old Apr 15, 2022 | 07:11 PM
  #151
Dagobert's Avatar
Dagobert
From: the Netherlands (Holland) _ Leiden (your 'Founding Fathers' original city of residence)
Thank you for the very detailed + animated answer, hattiude (+ sorry for late reply)
You really took some time to help us out the best way you can. I appreciate !
Enjoy the summer on your side...
Old Apr 16, 2022 | 12:22 PM
  #152
bill from tn's Avatar
bill from tn
This is my version of the heim joint conversion. It uses McMaster Carr heim joints, stainless steel button head fasteners, a spacer to eliminate misalignment, a nylock bolt on the back side to secure and the original shift rod and jam nut. I managed a machine shop and had one of our guys make several different lengths of spacers. I am certain that a well stocked hardware store would have something very similar in varying lengths that would serve the purpose. Google “small bolt spacer” to see what is available on the internet.
If you go this route or something similar check for clearance at the back of the stack up, especially at the front joint. Mine clears the cylinder fins by about 3/16” so cycle it through and adjust the bolt length as needed.
A friend had one of her original joints fail while riding with a group. Someone was able to zip tie and tape it together enough to get her back home so be aware the originals do occasionally fail. She is an aggressive rider but not a shifter stomper.
Old Apr 17, 2022 | 10:08 AM
  #153
F150HD's Avatar
F150HD
I used lock nuts on mine too
Old Apr 17, 2022 | 11:18 AM
  #154
hattitude's Avatar
hattitude
If you have clearance issues...
You can also use a chrome hex head bolt, put the head towards the cylinder, and then put a capped nut on the bolt, facing outboard..
JerryS63
Aug 25, 2013 07:40 AM
47909Rider
Jun 28, 2013 08:35 AM
themensh
"The Florida Crew"
24
Nov 7, 2009 12:48 PM
Swamp Tiger
May 27, 2008 06:46 AM
jakazz
Jul 11, 2007 05:18 PM
