Did the heim joint shift linkage mod today...
Hope that they do the trick.
I am so thankful for the information that I glean from this forum. If the replacement of this linkage creates no additional misalignment, at least these washers will prevent a disconnect if the heim joints should ever fail in the future.
FWIW.... Just my opinion, and I'm no engineer....
In a vehicle suspension set-up, like on a tie rod, steering link, or any suspension link, the heim joints could be subjected to very high stress/pressure, and would certainly cover a much larger range of their motion, than when used in the HD shifter rod.
I see the necessity for misalignment washers or misalignment spacers in a suspension set-up.
With the HD shifter rod, you'd have to be one helluva stomping shifter to get that heim joint to come out of the shaft end.
Even when stomping, most of the force will be applied in a more linear direction, putting much less stress on the actual joint, with a bolt through the heim joint, versus the OEM ball joint configuration, which applies the linear force to one side of the rod shaft. ....
IMHO.... I feel confident I'm much less apt to be stranded with the heim joint shifter rod with just a bolt, than the OEM ball joint... I don't feel the need to add any safety/misalignment washers in this specific application..
I also agree that the misalignment of the linkage will, most probably, not be great enough that a misalignment washer is necessary. But the way in which the misalignment washer is designed it serves as a standoff for the largest diameter (.875") of the washer from the face of the heim joint. Without this standoff distance a washer with a diameter larger than the joint could not be of as much benefit.
But, be assured, that your advice is not falling on deaf ears.
So to those who say "You dumbass, you could have done this cheaper." or to those who say "You could have made do with baling wire and a jar lid" I can only say "Who gives a damn?".
Whenever you send your daughter to her high school prom I am sure you will send her with the cheapest sun dress that you can find and tell her that she does not really need to have her hair done at the hair salon.
I had an uncle like that and he maintained his cars in the same manner.
Have a laugh.
Have a laugh.
