Rear end squeak
Old Feb 14, 2009 | 11:32 AM
buford's Avatar
buford
Default Rear end squeak
All,
I have a belt drive squeak on my 01 FLHR. When I role on the power I get a cherp coming from the rear drive. Had the HD dealer investigate this when I repalced a rear tire last spring, and they found no problems. I have since checked the bearings, belt, and drive sprockets (per HD manual recommendations). And cannot find any issues either.
Has anyone else experienced this issue and can help me pinpoint where to further look?
Thanks,
Old Feb 14, 2009 | 11:58 AM
gmc's Avatar
gmc
Make sure your belt is clean, just wash it off good.
Old Feb 14, 2009 | 12:00 PM
Deepsouth251's Avatar
Deepsouth251
Spray a little wd40 on the rubber muffler mounts and see if it stops. If it does replace them.
Old Feb 14, 2009 | 12:03 PM
n8dc's Avatar
n8dc
I had a wierd squeek on mine and just looked one day and found the one band clamp holding one of the heat shields on was loose.. Tightened it and all was well.
Dave
Old Feb 14, 2009 | 12:23 PM
im's Avatar
im
i had squeek as mention above and it was the black rubber muffler mount at the rear slip on...and did same as mentioned above...sprayed some PB Blaster into it and noise went away...wd#40 would work also.
Old Feb 14, 2009 | 02:31 PM
burnafatty's Avatar
burnafatty
That was a funny thread...glad you could work it out......LOL
Old Feb 15, 2009 | 06:46 AM
buford's Avatar
buford
Thanks for the reply's folks. I have had a sqeek in the rear rubber muffle mount and have replaced them. I haven't tried cleaning the belt before, which i'll give it a wurl.
But to let you know, the squeek is occuring as I'm going down the road. It also has a tempo, as I get faster, the squeek get's faster. Hence the reason I think it's the belt.
Could it be something in the primary that may sound like a rear drive problem?
Old Feb 15, 2009 | 01:40 PM
shakrr's Avatar
shakrr
does it chirp or squeak all the time? my chirp was at a certain speed regardless of accelerating or decelerating
Old Feb 15, 2009 | 01:53 PM
buford's Avatar
buford
It cherps all the time. Sometimes it's louder that other times. Especially when it is wet. When I ride through fog on the way to work, it'll start cherping loudly, then quiet down as it dry's out again.
Any thoughts?
Old Feb 15, 2009 | 02:24 PM
gmc's Avatar
gmc
Your primary is in oil so I wouldn't think it would be there. Wash that belt good, use simple green. It could be a sm stone got between the belt and the case or belt guard, do you see any marks on the outside of the belt. Also check the belt guard hasn't come loose and is rubbing. If your riding in WI it may just be telling you it's too cold, LOL!
Edit: Wash Belt and pulley.
