Hard Shifting
Old Mar 6, 2009 | 06:43 AM
Road Gypsy's Avatar
Road Gypsy
Could be a coincidence. I had a similar problem. We were packed and on the way when it became harder and harder to down shift. Finally got stuck in gears and neutral was impossible. Made it to a dealer. Bottom line was the cross shaft from the shift pedals to the linkage had some dirt in it. There is no lube fitting for this. They cleaned it up, wiped on a bit of grease, put it all back together and it shifted better than ever. So simple, but so frustrating. I have since drilled/threaded for a small grease fitting and all is well.
Old Mar 6, 2009 | 07:05 AM
paguy's Avatar
paguy
Thinking of it, same thing happened to me couple years back. 06' dyna. Tranny didn't want to shift when cold. Told that shaft between clutch and tranny hadn't enough grease. Shaft greased; problem gone.
Old Mar 6, 2009 | 07:10 AM
1flhtk4me's Avatar
1flhtk4me
Check the shift linkage for smooth operation.
Is it possible the primary is over filled?
Old Mar 6, 2009 | 07:17 AM
FastHoss's Avatar
FastHoss
When I did the heim joint mod to the linkage,I also put a zerk in the cross shaft,those two things really made a difference for me,thanks to the sharp members here.
plongson
2014-2024 Touring Models
15
Jul 20, 2014 08:21 PM
L0LIF 67
Oct 5, 2013 10:50 AM
vonivo
Jan 14, 2013 09:11 PM
YoDA
Oil Archive (no new posts)
Nov 5, 2012 01:44 PM
Rickey
Jan 15, 2012 09:44 AM
