Cams or 103"
Old Mar 6, 2009 | 10:50 PM
nemick's Avatar
nemick
Default Cams or 103"
I can't afford both right now, but I would like to improve performance somewhat. I don't need a rocket, but a bit more grunt would be nice. I currently have the FuelMoto package. Which would you do first, cams or 103"?
Thanks
Old Mar 6, 2009 | 11:59 PM
garyhendley's Avatar
garyhendley
i would go with the cams 1st get rid of the chain and go with gears -ride safe
Old Mar 7, 2009 | 12:21 AM
hpfatboy's Avatar
hpfatboy
2ND THAT, AND A WOODS TW-6G CAM. And you"ll have a grin from ear to ear.
Old Mar 7, 2009 | 04:25 AM
nemick's Avatar
nemick
Bumpety bump
Old Mar 7, 2009 | 05:12 AM
Johan96's Avatar
Johan96
My dealer says cam first. I did a cam on my lowrider. I felt the motor got more grunt.
Old Mar 7, 2009 | 05:32 AM
04harleyboy's Avatar
04harleyboy
Are you stating that if you went to a 103" you wouldn't change the cams?
Old Mar 7, 2009 | 06:04 AM
nemick's Avatar
nemick
I'm stating that, at this time, I can only do one or the other, so I would like to do the most advantageous first.
Old Mar 7, 2009 | 06:09 AM
stro1965's Avatar
stro1965
I just did cams on my '07 and can attest to a very nice performance improvement. I'm totally satisfied with the results. I didn't dyno it so I have no idea what it would look like on paper, nor do I care. I used Andrews 26H cams.
I disagree on going with gear drives on your '09 though, nothing wrong with those chains.
Old Mar 7, 2009 | 06:20 AM
04harleyboy
A 103" without head work and cams, is probably not going to make you very happy for the money spent towards the labor, I would go with the cam change. IMHO
Old Mar 7, 2009 | 06:42 AM
StreetGlider56's Avatar
StreetGlider56
Just save a bit longer and do this...
Screamin' EagleŽ Street Legal Stage II Kit for '07-later EFI Models - 103ci
The Stage II Big Bore Kit provides the parts you need to increase the horsepower of your EFI-equipped model. The kit increases the displacement of your Twin Cam-equipped model from 96 cubic inches (1584cc) to 103 cubic inches (1690cc). Includes Stage II (SE-255) cams, Big Bore cylinders, Big Bore flat top pistons, clips, and a Stage I Air Cleaner Kit with one-piece backplate, integral breathers, all mounting hardware, and gaskets. Also includes a high performance clutch spring. Separate purchase of cam spaspacers is required. See manual for proper procedure and cam spacer part numbers. Requires separate purchase of primary cover gasket. Not all components shown. 49-state kits include catalyst mufflers or headers, and California kits are street legal on California pollution controlled vehicles when used with Original Equipment mufflers. All EFI-equipped models require ECM calibration (priced separately). Regulatory approvals pending for '09 California kits.
Twin Cam 96 Stock vs. 1690 Stage I Kit Performance Chart
Silver
Fits '07 Touring models. Kit includes catalyst mufflers. 50-state street legal.
29907-07
MSRP US $1,199.95
Contact us for pricing and availability.
Please click below for special product information:
CAUTION
NOTE
