Change Shocks
Old Apr 25, 2006 | 01:59 PM
05Fatty's Avatar
05Fatty
Default Change Shocks
Anybody change their own shocks on a Street Glide/Standard etc... If so, how hard was it?
Old Apr 25, 2006 | 02:16 PM
UGGA's Avatar
UGGA
Default RE: Change Shocks
I just did mine on my Street Glide. I installed Progressive 440's, and it was very easy - perhaps 45 minutes total. You just need to make sure that you recheck your drivebelt tension when finished.
Doug
Old Apr 25, 2006 | 02:28 PM
05Fatty's Avatar
05Fatty
Do you have any tips or tricks? How did you go about it?
Old Apr 25, 2006 | 02:40 PM
UGGA's Avatar
UGGA
It's so easy that it's not even funny. Raise the rear tire off of the ground, pull the saddlebags, and then remove 4 bolts (upper and lower shock mounting bolts - 2 on each side). You'll want to use a torque wrench when reinstalling the bolts. In a nutshell:
1. make sure you have a means of lifting the rear tire off of the ground
2. have access to a torque wrench
3. check drive belt tension when finished. Some people use the HD deflection tool, I just go by feel.
That's it!
Doug
Old Apr 25, 2006 | 02:59 PM
Wally's Avatar
Wally
I agree it should be pretty straight forward, but, if you don't loosen the rear wheel, why would the belt tension change?
Old Apr 25, 2006 | 03:09 PM
UGGA's Avatar
UGGA
ORIGINAL: Wally
Two reasons:
1. He may be putting on a different height shock!
2. Even if swapping a 12" stocker for a 12" 440, it could change due to manufacturing tolerances. Mine did - my drive belt was tighter after installing the 440's. It takes very little difference in shock height to change the belt tension.
Doug
Old Apr 25, 2006 | 05:00 PM
05Fatty's Avatar
05Fatty
What did you torque them to and what is a good amount of slop in the belt?
Thanks a Million!!
Old Apr 25, 2006 | 05:20 PM
UGGA's Avatar
UGGA
ORIGINAL: 05Fatty
Thanks a Million!!
Sorry, but I don't recall the torque specs. I got them with my installation instructions for the shocks. I'll try to remember to look them up later today and post them for you.
As for the belt deflection, I have a rather unscientific approach. I just check the belts on new bikes at various dealerships and go by that. Better to be on the loose side than too tight though.
Doug
Old Apr 25, 2006 | 06:32 PM
05Fatty's Avatar
05Fatty
Thanks Again.
Old Apr 28, 2006 | 02:07 AM
GliderXXX's Avatar
GliderXXX
UGGA...how would you compare the ride with the 440's vs stock. I'm assuming the height of the bike remained the same as stock? Thanks
