Streetglide rear facia light
Old Mar 8, 2009 | 01:29 PM
RoadRanger's Avatar
RoadRanger
6th Gear
Default Streetglide rear facia light
The 3 bar light is not working, Is there a bulb or does the whole unit have to be replaced?
The manual does not say anything about a bulb.
Any help would be great. Thanks
Old Mar 8, 2009 | 01:37 PM
Harleypingman's Avatar
Harleypingman
It's a sealed, LED unit. If you are still under warranty, HD may replace it for you. Otherwise, you will need to buy one. Consider replacing it with the run/brake light version HD offers. It costs more but the added feature of the brake light is worth the extra $$$ IMO.
Old Mar 8, 2009 | 01:52 PM
HRLYSG's Avatar
HRLYSG
I agree with what was previously said and also suggest you check (if you haven't already) the plugin under the seat where the light connects to the wire harness just for giggles.
Old Mar 8, 2009 | 03:46 PM
RoadRanger's Avatar
RoadRanger
6th Gear
Thanks for the info. It is still under warranty. Will call H-D tomorrow and will check the plug.
Old Mar 8, 2009 | 04:10 PM
atrain68's Avatar
atrain68
Same happened to my '08 SG. They pulled the whole LED module and replaced it under warranty. Took them less than an hour. The dealership said it was a common problem with the units.
Old Mar 8, 2009 | 05:39 PM
RoadRanger's Avatar
RoadRanger
6th Gear
Thank you atrain68. Will be calling the dealership tomorrow.
Old Mar 8, 2009 | 05:49 PM
rjmac53's Avatar
rjmac53
let us know...
Old Mar 8, 2009 | 06:42 PM
gmurdock's Avatar
gmurdock
If it is the light. Ask the dealer what the difference is in price for the run/brake light? He might go for it?
Old Mar 8, 2009 | 08:04 PM
QSRYDR's Avatar
QSRYDR
I had the same thing happen to my bike.
I got home from having my tour-pak installed and while I was cleaning all the greasy fingerprints off it, I noticed the rear fender tri-bar light was out. I rode up to the dealer the next day and they said the light assembly was at fault.
My opinion is that when the dealer tech rerouted the AM/FM antenna cable up to the tour-pak he must have pulled a little too hard on the wiring harness. This was NOT the only problem I have had with ****-poor work from their service department.
Anyway they agreed to put the running light / stop light combo in there and only charged me the difference. It was around $20.
Old Mar 9, 2009 | 01:27 PM
RoadRanger's Avatar
RoadRanger
6th Gear
Well called H-D, they want to look at the light to see if warranty will cover the light.
the 07 streetglide goes in thursday. Will keep you posted. On another note when did a rear tire get so expanse, qouted $275 from the dealership.
