Road Glide owners??
Old Mar 8, 2009 | 09:37 PM
UPSGUY's Avatar
UPSGUY
Default Road Glide owners??
How do you get the plastic cover of of the headlights on the front fairing?
Old Mar 8, 2009 | 09:38 PM
harley0711's Avatar
harley0711
some will say it can be done - for me... I take the fairing off... I am just to chicken to do the pry and pull trick....
Old Mar 8, 2009 | 09:49 PM
IOSLVR's Avatar
IOSLVR
Either cover the tip of a small screwdriver with cloth or use a popsicle stick. It won't take much and it will come off.
Old Mar 8, 2009 | 10:13 PM
5 Speed Suicide's Avatar
5 Speed Suicide
this was posted earlier....I replaced my "bubble" this morning with the SERG black headlight bezel.
I took a small flat blade screwdriver (about 6" long), and covered the bottom 3/4" of it with 2-3 layers of masking tape, effectively making the tip about 1/2 inch wide.
I started at the top right "clip" location and gently inserted the screwdriver tip, and started pressing down against the bubble while putting gentle pressure upward on the edge of the fairing (just like opening a paint can, but very gently).
At the same time, I was kind of pulling on the top edge of the bezel, and the thing popped right out. The one on the left was much easier, (since the right one was lose already) and then the entire bubble hinged down from the top, pivoting on the lower attachment "clips".
It came out so easy, that I reversed the procedure, and re-installed it and removed it a couple of times. Very easy, and mine was really dirty on the inside.
I do like the look of the Black SERG bezel on the Vivid Black paint, but to be honest, the bubble looked pretty damn nice once it was cleaned well inside and out.
__________________
Old Mar 8, 2009 | 10:27 PM
hawg03's Avatar
hawg03
IOSLVR +1....easy...just don't be too hasty otherwise you'll scrtach something.
Old Mar 9, 2009 | 05:13 AM
skootchnc's Avatar
skootchnc
+2 popcicle stick.... although the screw driver works well
Old Mar 9, 2009 | 05:15 AM
UPSGUY's Avatar
UPSGUY
Thats what Im doing, Thanks!!
Old Mar 9, 2009 | 09:24 AM
stukes_md's Avatar
stukes_md
Can you give the numbers for the SERG parts?
Old Mar 9, 2009 | 10:52 AM
gary_montague's Avatar
gary_montague
Don't forget to hold your mouth in just the right position.
Old Mar 9, 2009 | 11:09 AM
gregsworld's Avatar
gregsworld
I'd pull it off alltogether and replace it with the black insert. Much much better looking than the plexiglass light cover IMO
Greg
