Road Glide owners??
Old Mar 9, 2009 | 03:12 PM
Beeracuda's Avatar
Beeracuda
I just use my fingertips at the tabs and pop one of them loose at a time.
Old Mar 9, 2009 | 04:06 PM
gdkenoyer's Avatar
gdkenoyer
Originally Posted by harley0711
some will say it can be done - for me... I take the fairing off... I am just to chicken to do the pry and pull trick....
And you've now set yourself up for the perpetual grief that comes from trying to put the dam fairing back in place with the headlight bucket in place.
As previously stated, the bubble comes off easily enough simply by prying up slightly with something thin (paint scraper, etc.) on the two lower tabs.
If you're curious what I meant by the first sentance, check out help, road glide fairing removal, scroll down to about post #14. Sorry the pics are gone in some past upgrade, but the text is still adequate.
Old Mar 9, 2009 | 04:12 PM
garyhendley's Avatar
garyhendley
you push down on the 2 bottom clips and pull out them do the same to the top 2 clips
its easy i broke off the tips on one side so i apoxied new lips worked fine -rdie safe
Old Mar 9, 2009 | 04:22 PM
Bingo's Avatar
Bingo
Originally Posted by stukes_md
Can you give the numbers for the SERG parts?
This is the black bezel that replaces the clear plastic bubble HD part # 69987-09
Did that to mine this winter. Some say the bugs and stones may bother the headlamp lenses as they are not hardened. I will have to keep an eye on that, but the mod looks better than dirt behind the bubble did.
IMHO
Old Jul 20, 2009 | 10:40 AM
krom nutz's Avatar
krom nutz
Does anyone know if one of these bezels will fit an 02 RG? guy at the dealer said it wouldnt fit his similar year model.
Old Jul 20, 2009 | 11:51 AM
Wally's Avatar
Wally
I think you should check with someone else. It should fit.
J-FRAME
Nov 30, 2015 06:15 PM
rdglider
Jun 18, 2011 09:08 AM
dklanecky
Mar 8, 2009 05:01 PM
NoTyme
Jul 30, 2008 08:51 PM
creep1
May 25, 2007 07:37 PM
