Burnt front fender!!!!
Old Mar 11, 2009 | 07:09 PM
Slacker8's Avatar
Slacker8
Sorry to tell ya but most dealers are on to the 21" burning the paint off the fender. Looks like this one is coming out of your pocket.
Old Mar 11, 2009 | 07:19 PM
busch's Avatar
busch
Make the call dealer says no move on fix it or ride it
Old Mar 11, 2009 | 07:24 PM
torq's Avatar
torq
as you speed increased the tire probably became narrower therefore became larger diameter causing it to rub. but that is just my idea. it sucks learning a lesson the hard way.
Old Mar 11, 2009 | 08:09 PM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
When you buy a new wrap fender I wan't to buy the old fender to cut the sides down for my project. I'll fix the paint....with new black.
Old Mar 12, 2009 | 08:22 AM
Peppa1's Avatar
Peppa1
You guys telling him to take it back to the dealer wonder why the service guys act like a** holes ? It's from people making mods to their bikes that end up causing a problem and then you want the dealer to pay for your screw up !! Give me a break. If you can't afford to "pay" then don't "play".
Old Mar 12, 2009 | 10:03 AM
tgaetto's Avatar
tgaetto
I had the same problem, I drilled out the bushing and moved it and tacked it in and re shot the fender.
Manish_Hawg's Avatar
Manish_Hawg
I had the same problem and here is the solution that will cost you the least amount of money.
1) Drop the front wheel and you can see on the inside where the tire rubbed
2) Spray paint the INSIDE of the fender where you see the rub mark black
3) Loosen the bolts and lift the fender up as far as you can
4) Install the wheel and ride for about 3 months
5) Drop the wheel and see if the black paint on the inside is not damaged
6) If no damage, repaint your fender and move on. (Just remember to lift it up as high as you can on the reinstall.
Old Mar 12, 2009 | 10:06 AM
phat96's Avatar
phat96
How much clearance did you have on the tire? either way with a new fender or with the old one it's going to have to be repainted. Did you drill out the rear hole to tilt it up?
Old Mar 12, 2009 | 10:30 AM
xxxflhrci's Avatar
xxxflhrci
x2.....
Old Mar 12, 2009 | 10:48 AM
Texas Fat Boy's Avatar
Texas Fat Boy
You got that right Peppa1
The guy was joking about the warrenty (he put a smily face right after he ask it) but some of these guys are serious. WTF !!!! give me a break. No wonder my service guy is always ina bad mood.
