How low can I go?
Old Mar 11, 2009 | 09:40 PM
rotorcrazy's Avatar
rotorcrazy
Default How low can I go?
I have an '07 RK Custom with stock rear shocks. Those shocks are already 1" lower than the rest of the touring bikes except for the Street Glide which has the same set up. If I drop the rear end one more inch will that cause any problems for me? That would be two inches lower than a stock touring bike.
Thanks for the help.
Old Mar 11, 2009 | 09:51 PM
Lucky 13's Avatar
Lucky 13
I run 11" rear with no scrubbing. Might depend on how much weight you ride with. I'm 160 and the wife is 125
Old Mar 12, 2009 | 12:11 AM
05 HD Deluxe's Avatar
05 HD Deluxe
I was running a 1" lowering kit in the rear. I did not have any problems with bottoming out. I weigh 200lbs. I plan on riding 2 up and did not want to take a chance with this kit. I took it off this past weekend. With it removed I can tell a difference in the ride solo. Little smoother. I think it is the shock angle with the kit. If I drop it again I am going to do it through the shock. Talk with bitchin baggers. They modify your stock shock.
2013superglideseattle
Jun 10, 2016 01:02 AM
rkcmike63
Sep 1, 2013 06:28 PM
bambamblazer
Dec 20, 2011 10:22 PM
rlbailey
Oct 23, 2011 05:41 PM
TexasBowhunter
Jun 7, 2007 10:37 PM
